Problem with Sharp Aquos LC-32D40U Television
32'' sharp aquos tv will not power up.
32'' aquos will not power up. The tv had not been used for about a month. When I went to turn it on, nothing came on. No lights of anykind. I tried it on another outlet, and checked the connection to the tv. No luck. tried to power up w/remote,same problem.
Posted by avatar on Oct 29, 2009
Solutions (1)
Best Solution
Look for the fault in power supply board. First check the fuse and replace it if burned. Then it could be a Voltage Regulator chip(s) burned (they look like transistor with 3 pins). You can test it with multimeter, they could have different pin outs, but generally it should read around 5 MOhms in 2 sets of 2 pins. Or it could be bad capacitors, look for swallen or domed capacitors; measure them with capacitance meter, sometimes they dry out with time. Or it could be other parts in power supply.
Testimonial: "The tests suggested may lead to something."
Add Your Solution
See all Sharp Aquos LC-32D40U Television Problems
