Bushnell ® HOLOsight Logo
Posted on Oct 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need the piece where instal the bateries bu un
I need the piece where instal the bateries but on the old model, batery is broken and it has broken the holo, the sopport is ok, so i need the piece
Anonymous
Level 2:
New Friend:
  • Expert 96 Answers
  • Posted on Dec 13, 2009
Anonymous
Expert
Level 2:
New Friend:
Answers
96
Questions
0
Helped
33709
Points
191
Take it into the manufacture to repair the battery, the holo or simply purchase a new Holo rig.
http://www.onesourcetactical.com/index.asp?PageAction=VIEWPROD&ProdID=216
Batery meter
Check your battery if it is properly seated. Try removing and re-install the battery.
Else, your battery could be bad (not charging). How old is your Dell?
1helpful
WHA IS MODEL MY BATERY BOARD
The 2032 battery is the standard cmos battery for all modern desktop motherboards.
I changed the bateries and now I can't cofigurate the lock.
Are you sure when you installed it that you didn't pinch any of the flat-tape wiring?
5helpful
Acer aspire one battery light flashes orange. When booting after a few seconds it shutsdown. Now all lights stay off. Can this acer netbook work without batery ? It doesn't seem to charge the batery
Finally I got it working again, after a lot of try's (just put the plug in for a few hours) the led was red again for a brief moment, then it starting to flash orange again.
I looked it up on a lot of forums, the problem is that the (old) bios doesn't charge the batery anymore when it is deeply discharged.
So I put the plug in and out for about 10-15 times , and the brief moment it is not flashing it's still charging. Until it is not deeply discharged anymore and then it is charging the batery like it did before.
But I still don't understand why it is not working without the batery inserted ??
4x4 doesnt work at all.no lights on the dash nothing.2001 s10 blazer can i fix this myself.looks like a corrided wie.tried it last year,she came back after i cleaned it up,but once i shut off the...
YOU MAST GET STEP BY STEP ON THIS PROBLEM TO RESOLVE FRST CHECK BATERY MEYBI YOU NIDED ANADAR VAN IF THIS IS TO OLD END CANT HOLD ELECRIC INSIDE .STEP 2 CHECK YOUR ALTERNATOR HIS CHARGING BATERY VEN MOTOR RUNING IF BROKEN FIX IT .3 CLEAN OLL ELECTRIC CONTACTS END INSURE GOOD GRAUND( - )POLE TO EVRY PART OF VECHILE DOORS ENGINE SHASHY EVEN THE DASH MAST HAVE GRAUND CONECTION YU MAST PUT THE DASH DAUNT TO CHECK EVRI LIGHT END HIS CONECTION DANGER:VORK SLOVLY TO IMPROVE CHIRCHUT.I THINK THE BIGEST PROBLEN IS VITH ALTERNATOR(BATERY CHARGER)-VISIT [email protected] for more help
Ac el aire acon dicionado de mi dog caravan 1994 tiene que recargarse en dos lugares o en solo un lugar
on most of this vehicles you have to bypass the power cord. you need to wire it strait to the batery and install a tago switch in order to work
2answers
How do I replace the starter
disconnect the battery post....remove the bolts holding the starter and then disconnect the wires to the starter.. install in reverse order
Batery hang problem
batteries have a charge memory in the, when you purchase a new battery the best thing to do is to fully drain the battery before charging it up, this will tell the battery that it needs full charge, if you charge the battery before this it will only charge the battery to a certain percentage.
what you need to do now is find a way to fully discharge the batteries
kind regards
Top Bushnell Optics Experts
ZJ Limited
ZJ Limited
Bill Eager
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
