Hi...dawn0736
Dryer timer switches are normally non repairable. You will have to replace the timer switch.
Be sure if you decide to do the work yourself, to get the correct timer switch, and remove one wire at a time from the old one and connect it to the new one.
This can be a daunting task for a novice if you do not do it this way.
I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good luck, I hope this helps
Was this helpful?
Yes
No
Popular Solutions for GE DBSR453EBWW / DBSR453EBCC
The upper plastic trim piece that goes around the drum inside the door (drum bearing?) on my on my...
(More)
The upper plastic trim piece that goes around the drum inside the door (drum bearing?) on my on my GE DBSR453EB2WW dryer is broken. How do I begin to disassemble the sides/top to get at this? Where do I start?
GE dryer DBSR453EB2WW Timer doesn't work. Dryer functions , but timer doesn't shut-down as should if...
(More)
GE dryer DBSR453EB2WW Timer doesn't work. Dryer functions , but timer doesn't shut-down as should if set at dial. Removed timer , applied power and observed plastic gear move slowly. What else can I try?
The knob seems striped will not turn and pliers will not turn it. The dryer was running perfect...
(More)
The knob seems striped will not turn and pliers will not turn it. The dryer was running perfect until yesterday. It is a G.E. But I cannot find a model # this is just a guess.
