2001 Dodge Durango Logo
Posted on Oct 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Getting a code p0121on my dodge durango 2001 - 2001 Dodge Durango
  • Marvin
    Marvin May 11, 2010
    Throttle/Pedal Position Sensor/Switch "A" Circuit Range/Performance
Anonymous
Level 3:
  • Master 350 Answers
  • Posted on Oct 29, 2009
Anonymous
Master
Level 3:
Answers
350
Questions
0
Helped
137432
Points
1214
Trouble code P0121 means: Throttle Position Sensor Voltage Does Not Agree With Map Sensor. You can replace the TPS for @ $30 from Autozone. Please vote appropriately and leave a comment. I hope this helps and Good luck.
  • Anonymous Jun 05, 2013
    Hi there: i did changed the throttle position sensor and the problem still there, and the idle is up and down and i change some of the vacuum lines too, but it could be a vacuum leak also which I have been checking and it could be that a cylinder has low compression too, so I am wandering what is really wrong there.
2answers
What does information center mean on a 2001 Dodge Durango
The term "information center" on a 2001 Dodge Durango typically refers to the vehicle's dashboard display that provides the driver with various information such as the current time, outside temperature, fuel level, and trip odometer. It may also include a message center that displays warning messages or notifications about the vehicle's systems.
2001 Dodge Durango is stuck ingear and its not first gear.
that shop missed the problem. dodge durangos have a common ****** problem. Is there any codes on it. It sounds as your 1st and 2nd shift solenoid are not working
1helpful
How do I fix codes p0551 and p0121 within dodge durango 2000 slt
go buy auto zone and have them erase these codes they willd do this for free
2answers
What would cause a p0121 on a 2000 Durango with a 4.7
See this posting ( http://www.fixya.com/cars/t5144223-p0121_code_in_2000_dodge_durango) They are having the same issue you are and there is some good advice there.
5helpful
2answers
P0121 code in a 2000 dodge durango, will he TPS make the ransmission shift spuratically.
Yes..... The TPS can cause this!!! Another sign of a failing TPS is for the rpm's to fluctuate up and down by 100-300 as you drive down the interstate at a steady speed on a level surface.
2001 Dodge Durango problems with rough idling and stalls.
Hello... Where to go next depends on how the Evap Gross Leak was fixed... Post it...
Thx.
5helpful
3answers
Need to know what the code p0121 is
The code P0121: (TPS) voltage does not agree with (MAP).
2answers
My check engine light is on. The code is P0121
I believe all the Mopar OBDC codes are the same. A list of the 2001 codes were posted on a PT Cruiser site here: 2001 Chrysler codes
Your error says the throttle position sensor and MAP sensor disagree with each other
Serges when idle
P0121 is TPS Reference signal faulty.
Has you vehicle been worked on lately?
Sound like could be a ground problem in and around the throttlebody. I would look there first. TPS don't go out that often, it is usually something else that cause's that to happen
Top Dodge Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Dodge Expert? Answer questions, earn points and help others
