If you have a V8 the thermostat is located under the coolant inlet tube. The tube is located on top of the engine, in the front about center. The thermostat is hard to change. Locate the upper radiator hose on your radiator and follow it to the engine block it is located on the top front part of your engine and you must lean over the front and look down onto the block to see the thermostat housing.
