you are having a convergence problem you will need to change a couple ics and possibly some resistors there to correct the problem
if you have the tools and knowledge and can solder its not to bad to do if not you may want to search for some local help from a service company depending on area cost should be 280 to 320 for that repair
the color tint is like pink on peop[les faces and it used to go to the correct color after it was on...
(More)
the color tint is like pink on peop[les faces and it used to go to the correct color after it was on for awhile but now it stays on the odd color. It seems as though the green tint is out
My tv is a Toshiba 55H71 but this is the closest number i found to it. We are having problems with...
(More)
My tv is a Toshiba 55H71 but this is the closest number i found to it. We are having problems with ours having lines across the screen and the longer it is on the worse it gets. There are only two that run verticle and many that run horizontal. What can we go to fix this?
TV was flooded. Already cleaned and ready for re-assembly. We need a circuit diagram to check...
(More)
TV was flooded. Already cleaned and ready for re-assembly. We need a circuit diagram to check accuracy of reconnection.
