No audio on my radio at less than 1/2 volume. While listening to the radio at road speed, the radio goes dead as I slow down and starts again when I speed up.
cruise controls are controlled by several units
VSS or road speed sensor, clutch and brake sensors , engine speed (tacho) and the on/off switch
cruise controls will disengage automatically if the road speed is too slow ( higher for manuals than autos ) so if the road speed is below around 20mph it may not engage at all as the VSS says it is too slow for the engine rpms
check all sensors for adjustment
You may just need a FM signal booster for your antenna. The issues with the volume going up and down, does this occur when the vehicle is sitting still? If so, yes there is still a problem. If the volume gets louder as you speed up, and quieter when you slow down, this is a function of the unit. It automatically controls the volume to compensate for road noise. Consult you owners manual regarding how to disable this function.
If the issue you are describing follows this pattern (when slowing down, the radio turns down in volume, and when speeding up it turns up in volume), then your vehicle is equiped with an automatic volume control. This function was to allow the operator not to have to touch the volume control while driving. The volume increases to compensate for road noise. You should have a function control button that will allow you to turn this function off. Hope this helps.
I can give you most of your answer and it depends on the Radio. Ford has a speed-compensated Radio that will adjust the volume of the Radio to the speed of the car. This feature means you will not have to adjust a radio down at a stoplight or when going to a drive-thru.
Then when the car speeds up and engine and road noise increase, so does the volume on the Radio. So you will not have to adjust the volume of the Radio when you drive.
You need to fix the speedometer to get the radio to work correctly. You probably have a sensor connector or the sensor itself making the problem. Go to an Autoparts store and get a sensor and it will probably work fine.
if the radio still has power the audio amplifier ic in your radio has failed. take your radio to an electronics repair shop or, replace the radio; this not something you can fix unless you know how to use an oscilloscope.
Check the dealer and see if your radio automatically adjust to your speed. Some radios were built to raise the volume when driving at higher speeds and when you get in slow traffic or when you stop it would automatically adjust down the volume. You can also go to a Radio Shack and get a spray cleaner for electrical parts and pull the volume knob off of your radio and spray the volume control and turn it rapidly to remove any hidden dirt on that volume control.
Hold the volume button down until the clock setting comes on. Then press the same button until you see "Demo:On" on the screen. Turn the volume either up or down to change the setting and then hold the volume button down until you see "AUX" or "TUNER" on the main screen again.
