Olympia Mastertype 3 Typewriter
Problem for Olympia Mastertype 3 Typewriter
Turned on the typewrite and after it goes through
By rdacke on Oct 29, 2009
Turned on the typewrite and after it goes through its setting, it starts to beep continuously and nothing works! How can we fix this?
Solution #1
posted on Nov 11, 2009
Not Rated)
LUCKYTECH
Rank: Wiz
Rating: 79%, 5 votes
Lubricate the mainshaft that the carrier travels on with a 10 weight oil. Do not use WD 40. Wipe shaft with a soft cloth and reluricate.
Was this helpful?
Yes
No
Popular Solutions for Olympia Mastertype 3
Questions and Unsolved Problems for Olympia Mastertype 3
Do you recommend Olympia Mastertype 3 Typewriter?
Answer
Answer
I have a Xerox 610 Memory typewriter. I can't install the printwheel--how do I do this?
Answer
It skips every 13th space. How can I remove this setting?
Answer
SM9 that skips every 13 character. In other words, it types 12 characters, and then skips a space.... (More)
Answer
how do you turn off the memory feature to use the machine as a normal typewriter?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Olympia Mastertype 3...:
Top Typewriter Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Typewriter Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
