I have 2 lg DVD writers (i.e. GSA 4120B & GSA H10A).My Regions on both units (both on the same computer)are both set on '0'.Is it possible to make at least one of the units "REGION FREE" ?Thanks
for burning dvd try using a program SlySoft AnyDVD for veiwing try vlc media player. VLC is one of the free software and open source DVD players that ignores DVD region coding on RPC-1 firmware drives, making it a region free player. However, it does not do the same on RPC-2 firmware drives. If both are RPC-2 then you might have to try a program like DVD Region-Free 1.0
I have a VIA PCI to Serial ATA Raid Controller that is intalled and reading the VIA software. I have...
(More)
I have a VIA PCI to Serial ATA Raid Controller that is intalled and reading the VIA software. I have a LG GSA-H62L SATA drive with only the narrow red cable connected to to SATA slot on the VIA card. Again, no power to the LG Drive.
I can still use the usb port but when i plug the external dvd on the usb it says power surge and i...
(More)
I can still use the usb port but when i plug the external dvd on the usb it says power surge and i should unplug but whenever i plug it again the message still appears.. What should i do? before the dvd works fine it just happened recently and i dont know how to fix? can i still use my dvd? please help me and one more thing it smells burning whenver i connect the plug.. but the usb plug and the usb port on my computer is not the problem because i test it on other computers it happends the same. The dvd is still working because i can eject it and it lits up. thanks hope someone could help me to fix my dvd.
Does anyone know why an LG Lightscribe Burner, Model GH22LP20-OEM would not work in the Master...
(More)
Does anyone know why an LG Lightscribe Burner, Model GH22LP20-OEM would not work in the Master position? I worked on this problem for days and finally installed it in the Slave position and it works fine. It also caused Internet Explorer, shut down problems when it was in the Master position. Thanks.
My region is currently set on 0, how can I reset it two region 2 or make it region free? Cheers...
(More)
My region is currently set on 0, how can I reset it two region 2 or make it region free? Cheers Stevie
I just bought a DualBrite Motion Sensing Diecast Latern.
The lights stays on instead going off and...
(More)
The lights stays on instead going off and coming back on when there is motion.
