Hi there, when I switch on my Compaq 6720s it powers up (you can hear the fan spin) then powers off immediately (LEDS go off) I have tried known good ram. Thanks
Comments:
Oct 29, 2009
- Thanks for the advice. I am using a known good PSU - so that rules that out - any other ideas (I am beginning to think GPU) ?
Have you checked that the power supply is giving charge to the computer, sounds like it's trying to run on battery power, but if the 'power brick' isn'rt working properly, this can give the symptoms you describe
Was this helpful?
Yes
No
Popular Solutions for HP HP Compaq 6720s Notebook PC
I have recently tried to increase the RAM in my 6720s but have now found out that one of the two...
(More)
I have recently tried to increase the RAM in my 6720s but have now found out that one of the two slots does not appear to be working ie computer won't re-boot with just that slot in use or it does not recognise the additional RAM in that slot. How easy/costly is this to be repaired please?
i tried installing drivers for hp 6720s ... flash bios's driver was also installed...bt wen i...
(More)
i tried installing drivers for hp 6720s ... flash bios's driver was also installed...bt wen i restared the notebook...dint boot...blank screen.. do i have to re-program the bios?
I have a HP Compaq 6720 laptop that does not connect to the modem first time ever. I have to restart...
(More)
I have a HP Compaq 6720 laptop that does not connect to the modem first time ever. I have to restart the laptop and go through numerous fault finding, often resulting in powering down the modem and starting again. Is it a fault with the wireless adapter? Thanks Paula.
