MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
You're getting a heat roller low temp detection on the fuser in your copier. The fuser is the device that provides heat and pressure to the toner to bond/fuse it to the paper (it's that black, rectangular box in the upper part of the body when you open the left-hand side of the door).
Chances are a peice of paper is jammed up inside and blocking the sensor (probably a small peice that tore from a page someone tried to pull from the fuser). That or the temp sensor is defective.
You will need to get some developer. Usually you can get it from who you get your toner from.
Remover all developer out of the cartridge using a vacuum. Carefully remove all developer off of the mag roller as well.
Install developer evenly into the cartridge.
You will need to run a service code to initialize the developer and reset the counter. If this isn't done properly, the developer will get contaminated and have to be removed again.
You should obtain a service manual for step by step instructions on how to replace the developer for your particular copier.
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127 PRESS # PRESS = PRESS C PRESS = TYPE 16 PRESS ENTER BUTTON (the button for making photocopy) PRESS 'OK' TWICE Note: be fast in pressing all the buttons. FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
