HL-DT-ST DVD-RW GWA-4082N is not working properly. I had no problems with this hardware before but suddenly it cannot read either CDs or DVDs. I checked the Device Mananger and the driver's status is 'working properly'. What should I do?
Comments:
Nov 02, 2009
- I don't see any UpperFilters line...can that cause the malfunction??
1. Start > Run. 2. regedit 3. Navigate to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class in the Registry Editor dialog box and select the {4D36E965-E325-11CE-BFC1-08002BE10318} key, which appears as a folder. 4. Select File > Export 5. save the file to the Desktop in case you need to restore it 6. In the right panel of the Registry Editor, select the LowerFilters line, and then choose Edit > Delete. Click Yes in the Confirm Key Delete dialog box. 7. Do the same for the UpperFilters line 8. Close the Registry Editor. 9. Restart Windows.
Comments:
Nov 02, 2009
- go to
Start>Run
type "regedit"
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\CDRom click on start
change the value from 4 to 3
restart the computer
You could try a cleaning disk in the drive, the laser may be dirty. Check that the cables are firmly connected (this means opening the case). If all these are OK then I am afraid you may need a new drive as it is not really an option to repair these drives.
Hi my name is kerrie.. I am looking for a gz-mg26 burner. CU-VD10 SHARE STATION.Apacer AD330 DVD...
(More)
Hi my name is kerrie.. I am looking for a gz-mg26 burner. CU-VD10 SHARE STATION.Apacer AD330 DVD BURNER.I have looked ever where and can not fine one because it is a older camera they dont make them anymore. And the new ones do not work on the older one. So if there is anybody out there how would like to sell me one please help me out. thank you. kerrie.
NO matter what blu ray player I use my LG ggw-h20 blu ray drive won't play Blu ray movies. I have an...
(More)
NO matter what blu ray player I use my LG ggw-h20 blu ray drive won't play Blu ray movies. I have an intel g45/g43 Mobo with the latest drivers installed for everything. Please help.
