This problem should be removed because:
Problem with Projection Televisions
i had gotten a RCA P52731WK chassis PTK169PGB. my uncle had given me the tv, when i plugged it in there is a loud electrical snapping sound and then shuts off. he told me 4 years ago he had same
problem and he had replaced the bulb. could that be the problem?
Solutions (1)
Best Solution
This set does not have a bulb. It has three picture tubes which can be mistaken for a bulb. It is possible that one of the three tubes can be leaking high voltage or you could have a bad high voltage transformer. Either way this is a dangerous area to be working and you would probably want to get some professional help. Thanks
Testimonial: "thank you for the info it was very helpful"
rca ctc195 big screen tv trouble
turned the tv off and went to bed, in the morning turned it back on, but no picture just snap snap snap pause and snap snap snap again. Do...
tv wont come on
hello my tv wont come on at all now it is the rca p60921 i checked the fuse and it was fine i even had the power supply replaced still...
I have a 1994 RCA projector TV model# p52731wk....
I have a 1994 RCA projector TV model# p52731wk. The picture is all blue. How do I change the bulbs?
My T.V. won't come on.
T.V. was working fine then made a loud pop and turned off. I checked the fuse at the power cord and it's good but still nothing. RCA...
Add Your Solution
samsung dlp tv shutting down
After working well for a number of hours the TV shuts down and restarts then goes through the shut down restart sequence...
can't get into chan.memory
no picture or sound can't change channels
CAN'T GET INTO CHAN.MEMORY
Fix-O-Meter
131
131 people viewed this problem
- 1 person found this problem to be helpful.
- 0 people are following this problem. Be the first!
Top Projection Television Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
