Whirlpool Cabrio  WTW6600SBT Top Load Washer
Problem for Whirlpool Cabrio WTW6600SBT Top Load Washer
Agitator inside the drum is not moving during wash
By dvkumar on Oct 29, 2009
agitator inside the drum is not moving during wash
Best Solution
posted on Oct 29, 2009
Very Helpful)
bschilz
Rank: Guru
Rating: 87%, 627 votes
Seems to be a common problem with Kenmore and Whirlpool machines. Follow this link to a good explanation of what's going on and how to fix it.
http://fixitnow.com/appliantology/wpdd_dogs.htm
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
Not Rated)
drallim
Rank: Guru  Whirlpool Washers & Dryers  Expert
Rating: 87%, 721 votes
Remove the agitator and inspect the plastic block on the shaft end. Is it split, or the interior splines stripped out? If so, replace the part. Leave the parts off and run the wash cycle--does the shaft turn back and forth? If not, then likely the coupling of the motor to the transmission has failed and needs to be replaced. Go to: http://www.fixya.com/support/r385252-replacing_motor_coupling_ w... by jsrock516. Give him a pat on the back if this helped.
Was this helpful?
Yes
No
Solution #3
Not Rated)
spamdmpstr
Rank: Guide  Washers & Dryers  Expert
Rating: 82%, 2 votes
whirlpool uses a coupler between the drive motor and transmission. and is the most common failure point. if the motor runs and the drum dont its this rubber coupling ..this costs about five dollars and is not too difficult to change if your mechanically inclined. I have always installed them as a precaution when preforming service on older wirlpools..or when they fail as seems to be your case.
Was this helpful?
Yes
No
Popular Solutions for Whirlpool Cabrio WTW6600SBT
Questions and Unsolved Problems for Whirlpool Cabrio WTW6600SBT
Do you recommend Whirlpool Cabrio WTW6600SBT Top Load Washer?
Answer
Answer
My washer stops at either 20 mins or 8 mins. The first load always goes good and after that... (More)
Answer
Now and again light will flash and letters LD will come on. We thought load was uneven and moved it... (More)
Answer
is there suposed to be water in the balacers top and bottom on the basket. cabrio washer
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
