FL OFF could indicate a problem with the power supply or the cooling fan inside the receiver. Try unplugging the unit to reset the error code. If the error persists, the receiver needs to be serviced. If the Pioneer VSX-90 is still under warranty (1 year), contact the manufacturer. Otherwise, decide if it is worth fixing (including the shipping costs and minimum service fee).
I wish that I had better news for you. (There are service manuals available for sale online. I know nothing about these vendors.)
Hello Awelani,
The error code of F1-90 means the following;
Communication trouble between the decurler and the downstream units. OR possibly;
Communication trouble between the decurler and the units connected to the downstream of the decurler.
CAUSE; Noise on the communication line, control PWB trouble, disconnection of connector or harness.
REMEDY; Turn OFF/ON the power. Check connection of the connector between the decurler unit and the downstream units of the decurler. Replace the control PWB of the downstream units of the decurler.
On page 256 of the D-90 users manual it says that ERR indicates a camera malfunction that can be cleared by releasing the shutter. On my D-90 when this occurs, I have to turn the camera off to make the shutter release. Sometimes, but rarely, I have to remove and reinstall the battery to get the shutter to release.
The manual also says that if this error occurs frequently or persists to contact n authorized Nikon service center. I suggest that you contact Nikon tech support at www.nikon,com before you contact a service center to see what tech support advises. I have heard of people resolving this problem by upgrading the firmware (camera software). Nikon tech support can tell you if this will help.
This information works for my D-90 and could work for your D-40
Service Fuser Error appears when the fuser does not warm to the required temperature. For this error on this Lexmark model T632, the manual states you should power off the printer and power it back on, and if it is not plugged into a wall power point, change it to a power point mounted directly on the wall. Personally, I never got a Lexmark printer to work doing this, but this is in the manual. If this won't help, and the printer is under warranty, you should log it in with the servicing company.
If the printer is out of warranty, your next option is to change the fuser which costs around $90 on Ebay.
E-90 error is a carriage error. You can reset printer by turning it off and unplugging it then check inside the printer after opening the top cover, check for any parts that are damage or any foreign objects inside. Then replug and turn it on, if all fails then chances are the product is damage or broke. call epson if you still have a warranty for replacement or have it service.
