I am trying to remove the outer casing of the kirbyHeritage II vacuum cleaner. I want to replace the plastic flywheel and remove a nail from inside the housing. I removed three screws that hold the casing together
but I have a problem in the switch area. How do I dissassemble the switch.
There is a push in type flat plastic switch trim cover over the metal housing surrounding the switch.. You must unplug the cord, gently pry around the trim cover and you will find a screw, an irregular one underneath holding the switch in place. DO NOT OVERTIGHTEN when reinstalling this one or you will crack the switch.
Once removed the rear housing will come off. Then you will see several new philips round head screws holding the front housing onto the vac.With all screws removed the housing should open easily but there may be dirty film inside holding the halves together. The fan shaft will unscrew revealing the fan, a spacer behind and perhaps two different spacer washers. Install the new fan hand tight, washers and spacers in same order... Good effort figuring this one out. Please post back with results.
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
Just the information I needed. Direct and to the point. I am grateful...David
" - fariasd
vacuum for mohawk smartstrand carpet, what is the best vacuum to use? We need a new vacuum any way....
(More)
vacuum for mohawk smartstrand carpet, what is the best vacuum to use? We need a new vacuum any way. We have used an oreck and the kenmore intiution. Both of these vacuums are very hard to push on this carpet. It gives you more than a workout for the day. Any recommendations??
I am having difficulties in properly assembling my cleaner. The water is running out on the floor...
(More)
I am having difficulties in properly assembling my cleaner. The water is running out on the floor when I turn it on. It is coming out on the right hand side because it does not have any where to go (from my point of view)
