OUR ADMIRAL ICE MAKER HASNT DROPPED ICE IN ABOUT 2-4 HRS. WE ALWAYS ADJUST THE ARM MANUALLY WHEN NEEDED AS THERE SOMETIMES IS SOME ICE CUBE BUILD UP. THAT DOSENT SEEM TO BE THE PROBLEM NOW. THE TRAY IS ABOUT EMPTY AND I CHECKED IT AGAIN AND MADE SURE THE ARM WAS DROPPED DOWN SO THAT ICE CUBES WILL DROP. IT HASNT HAPPENED YET. I CAN FEEL ICE IN THE ICE MAKERS WITH MY FINGERS. ANY IDEAS?
They sometimes get frosted up and don't want to work the motor properly...if you can get the face of it off, take a hair dryer and heat it up until the frost melts off...don't spin the fan motor if you have one on that unit. Then put it bad on and see if that will help if it doesn't you may have to replace the whole unit. They run around $190 if you do it yourself...not too hard of a job.
At first the washing machine would overfill on the rinse cycle, but not everytime. At first we...
(More)
At first the washing machine would overfill on the rinse cycle, but not everytime. At first we thought it was a drain problem. Today, it began to overfill on the first washing cycle. The water did not cut off even when it was full and began to agitate. I turned the machine off and the water still began to fill. So I turned off the water line. What is going on?
When my washer gets to the rinse cycle, it stops. You can hear a slight hum and then it goes dead. ...
(More)
When my washer gets to the rinse cycle, it stops. You can hear a slight hum and then it goes dead. After several minutes, you can start the washer again with no problems.
