Moen 22174 Basket Strainer with Drain Assembly In Stainless Steel - 2''
Problem for Moen 22174 Basket Strainer with Drain Assembly In...
How to attach the drain assembly, in a backwash
By cruisinhairf on Oct 29, 2009
my shampoo bowl in my hair salon, is called a 'backwash unit', you stand behind it to shampoo hair...well, the metal drain assembly is 'loose' and water is leaking around the edges. I want to fix it without calling the plumber! The metal drain assembly is loose enough that i can actually pull it out of the basin. It appears to need to be 'screwed' into the basin fixture, but it won't fit tightly. I used this shampoo bowl without trouble until recently. It just started leaking suddenly..I don't know what to do!
Solution #1
posted on Oct 29, 2009
Not Rated)
snakeboy309
Rank: Master
Rating: 0%, 0 votes
you could try a sealent from your local hardware store ask the people there tell them your situation and they will tell you what you need
Was this helpful?
Yes
No
Popular Solutions for Moen 22174 Basket Strainer
Questions and Unsolved Problems for Moen 22174 Basket Strainer
Do you recommend Moen 22174 Basket Strainer with Drain Assembly In Stainless Steel - 2''?
Answer
Answer
my pacemaker starts throbbing in my abdomin at 17.15 hrs every day which lasts for 3 minutes. is... (More)
Answer
Trying to find basket strainer for Kohler cast iron sink made in 1999 (975823-O-AA).
Answer
lock not splits after a couple months, replaced several times for $25 each, cannot find just the nut... (More)
Answer
I Have a FRANKE Fireclay white Farm sink only 90 days old And I must have dropped something in the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Basket Strainer Experts
Top Plumbers
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(866) 897-9936
316 2837038
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
