Kenmore 42822 Front Load Washer
Problem for Kenmore 42822 Front Load Washer
I guessed my motor coupling on whirlpool washer
By steve_ackerm on Oct 29, 2009
i guessed my motor coupling on whirlpool washer needs replaced; now that i have the part, i began to replace it, but the existing one is not broken; is it the problem?
Comments:
Nov 04, 2009
- it filled and drained, but not agitate and not spin. the new drive coupling fixed it; it must have just been worn out. Now, it does not stop filling. there was a piece of white plastic about 3 inches long with a round top. I'm not sure where it came from. Thanks for your help!
Clarification Request
Posted by jballiett000 on Oct 29, 2009
I'll need more information to go on, I can only guess what the actual problem you are trying to fix is. The usual sign that a coupling is out is that it will fill and drain but not agitate and not spin. If it does not do any of these, it is possible it's the motor or timer, if it agitates but does not spin or spins but does not agitate it could be the transmission is bad or the motor will not reverse direction. More info is definitely needed.
Posted by tcochuck on Oct 29, 2009
you have this posted in the front loader section.. front loader washers do not have a motor coupling, they are driven by a belt and two shivs(pulley). what model number do you have?? and why did you think the motor coupling was bad??? best of luck, ttfn
Solution #1
posted on Oct 29, 2009
Not Rated)
ash0434
Rank: Guru  Washers & Dryers  Expert
Rating: 90%, 36 votes
Was the motor working before, but no spin action.
Make sure the plastic tripod like pieces for the coupling are not worn out on the shaft of the motor or the gear box. Sometimes they round out on the shaft and slip.
If they are O.K. then you might have a problem with your gearbox, neutral/break kit.
Ash
Was this helpful?
Yes
No
Popular Solutions for Kenmore 42822 Front Load
Questions and Unsolved Problems for Kenmore 42822 Front Load
Do you recommend Kenmore 42822 Front Load Washer?
Answer
Answer
I need to know the dimensions of the washer especially the depth to see if it will fit in the... (More)
Answer
won't turn on when I select a cycle and hold the center button down.
Answer
it would stay on 45min and now it say panel is locked is there a reset button on this machine
Answer
My 110.42822 will not spin & drain.I can heard the motor humming, but that's it. I took out... (More)
Describe your Washing Machines problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing Machine Experts
Top Washer & Dryer Repairmen
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
