Viking DDBB363 Bottom Freezer Refrigerator
Problem for Viking DDBB363 Bottom Freezer Refrigerator
The freezer stop working and then the refrigerator
By koonj on Oct 29, 2009
the freezer stop working and then the refrigerator also stopped a few days later
Best Solution
posted on Oct 29, 2009
Very Helpful)
woodchuck789
Rank: Guru  Refrigerators  Expert
Rating: 91%, 618 votes
The evaporator coil behind the cover on the back wall inside the freezer will ice up under normal conditions. Every 8 to 10 hours for around 20 minutes the defrost timer (or in most newer models the electronic adaptive defrost control) will turn the defrost heater on to melt the built up ice. There is a defrost thermostat which prevents the heater from overheating the freezer by breaking the heater circuit when the temp reaches close to 32 degrees F. The entire cooling system shuts off during the defrost cycle and starts back when the timer advances through the cycle.
If this ice is not melted it will continue to build up until the air can’t flow over the coil to circulate the cold air through the freezer and into the fridge. The temperature change in the fridge is usually noticed first followed by the freezer.
If the defrost thermostat is bad it can prevent the heater from coming on OR it won’t turn the heater off when it gets too warm. It is clamped to the evaporator coil at the top to sense the temp. If it appears to be misshapen it is bad.
With an ohm meter it should show continuity when cold and none when warm.
You can also bypass the thermostat to see if the heater comes on then. If it does then you know the thermostat is bad and needs replaced.
The defrost heater is located on the evaporator. It is in a tube which is at the bottom and can also go up the sides of the evaporator. On some types you can see a burnt spot if it’s bad. With an ohm meter it should show continuity from end to end when disconnected from the wiring in the freezer. You can also test the wiring for voltage when it’s in the defrost mode.
If you have a defrost timer you can test it. It can be located under the fridge behind the kick panel on the front. Some are in the fridge with the controls at the top. You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer because that means the timer is not running. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
If you have an adaptive defrost control instead of a timer, replace it if the heater and thermostat test good. It is located in the fridge with the controls in some models and on the back in others.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Viking DDBB363 Bottom Freezer
Questions and Unsolved Problems for Viking DDBB363 Bottom Freezer
Do you recommend Viking DDBB363 Bottom Freezer Refrigerator?
Answer
Answer
fan in refrigerator compartment howls. need replacement
Answer
We have a Viking VCBB36345S. We had a power outage and our icemachine stopped making ice. Water is... (More)
Answer
We have a Viking Professional and we have set it at the mid setting and can't seem to find the right... (More)
Answer
I have a one year old Viking refrigerator DDBB363RSS (bottom mount freezer). Last night, it started... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
in , OH
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
