Well there are two things you can test before replacing the keyboard entirely. First thing is if you have a usb keyboard try plugging that in and see if problem repeats itself on that keyboard, second thing is try turning off the computer and reseating the keyboard and see if it repeats the problem. If you have to replace the keyboard, might i suggest the warranty first, asus normally has a pretty good warranty, then try a good shopping search to find replacement.
asus eeepc 4g white screen on lcd nothing visible but output ok on external monitor output.tried Fn...
(More)
asus eeepc 4g white screen on lcd nothing visible but output ok on external monitor output.tried Fn F6 to change goes off external monitor but does not change white screen Lcd any ideas please
my eee pc's camera goes all sepia and green shaded whenever i use it on skype or other web cam...
(More)
my eee pc's camera goes all sepia and green shaded whenever i use it on skype or other web cam applications, how do i fix this?
I have an ASUS F5RL-X3 I can not access the recovery console using F9, nor can I repair it using OEM...
(More)
I have an ASUS F5RL-X3 I can not access the recovery console using F9, nor can I repair it using OEM WIN XP Pro disk. I have changed boot priority so that CD is first device however it goes to HDD. I just want to get it started in recovery or DOS so tat I can manually fix registry and run chkdsk /p/r. F9 does not work!
