Question about RCA F20352SF TV
When i hook up dvd/ps2 i cant get it to show up on the screen
I have a 1994 rca model#f20352sf colotrak plus. i got this from a friend who got a new television and gave this to me for games or whatnot [since its bigger than mine]. i connected the red/yellow/white/ plugs to the correct jacks, but i dont know how to get the appliances to show up. they and the tv run fine im sure. the tv has a menu, channel up/down, volume up/down, and power buttons. i dont know how to program the channels.
thanks for any help, please use easy to understand language as its easier to understand.
  • Anonymous Jul 05, 2008
    I just came across the exact same TV, and even after carefully going through the menu functions, I haven't been able to get it to switch to the video imput mode. Unless thsre is some secret ninja way of making this TV go into video mode, it seems you can't do it without the remote. Does anyone have any ideas?
  • mekab08 Dec 05, 2008
    STILL TRYING TO GET DVD PLAYER TO WORK WITHOUT REMOTE TO RCA TV F20352SF
You can use the remote with your sat/cable (you have to find the right code to make it control your TV) but we used our Direct TV remote to go to 00 and it worked....I would assume using a Universal Remote would work also.....
Posted on Dec 31, 2008
You have to have a remote control to set the chanel to 00. You cannot set the chanel to 00 with the chanel buttons on the front of the tv.
Posted on Dec 26, 2008
  • 3 Answers
You have to switch it to av mode either by remote if there is no any othe way on the controls.
Posted on Jan 04, 2008
I programmed TV to my Brighthouse cable TV remote. Then I hit (video source) button. That changed TV to AUX function for my DVD player
Posted on May 31, 2010
How do I hook my old PS2 to my RCA TV with my converter box?
RF cable coax out to TV from the RF Modulator .....RCA jacks "red-yellow-white from ps2 to RF modulator "its not called a converter box"//lol Put the TV on channel 3 you should see the ps2 screen. Same way you would hook up a DVD player to a CRT TV..heres a video
TVs DVD Players How to Connect TV DVD Player VCR With Modulator
Mar 22, 2015 | RCA Televison & Video
I HAVE A RCA 20 INCH tv and i can't get the channels to change i want to hook up a game machine and i'm having trouble its saying some channels are erased how can i fix it so i can hook it up for my...
Do a factory reset to this TV, and check. To do this, you have to enter its service mode option. If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Service mode entry, adjust and exit procedure to many popular brand TVs are given in detail.
Jan 24, 2014 | RCA F20352SF TV
We had our ps2 hooked up to an old rca tv and was using the satelite remote for it channel had to be on 00 for the ps2 to work. We got a new tv and hav moved the rca and ps2 to another place but don't...
New tv's don't use dead channels like 00 anymore for there inputs.. They use sources to change from different inputs.. Make sure you have your ps2 hooked up into input plugs on the tv and then turn it on the ps2 then look on the new controller for the tv & find a button saying source .. Press that until you see your ps2 on the screen. If not check your connections try again.
Feb 03, 2012 | RCA Televison & Video
I have a 25 inch RCA Colortrak Plus TV and I am trying to play on my PS2, what is the correct channel to use?
Some of the older set audio/video input is connected to channel 91,92, or 93.
SD TECH
Jul 23, 2011 | RCA F20352SF TV
Have flat screen tv rca model 46la45rq and want to watch cd movies we just rented but cant find way to hook up our dvd
You hook the DVD player to the RCA jacks on the buttom back of the set, where it says Video input.
Apr 18, 2011 | Televison & Video
RCS colortrak f20352sf: Can't view video source (Wii). I've wiggled the cables, cables are hooked up properly, Channel 91 doesn't work. In the setup menu, next to channel 91, it says clear.
I just bought the same TV second-hand and had the same problem. Solution: Use remote to change channel to 00. You can't display channel 00 using front panel - a remote is required. I have a very basic RCA universal remote, & it does the trick.
Dec 07, 2010 | RCA F20352SF TV
Program RCA F20352SF television to DVD player
Aug 11, 2009 | RCA F20352SF TV
Blurry Screen on Panasonic CT-32HL44
I solved my problem. Apparently the RCA cables where missing with the image. So I bought some Component cables and that fixed my problem.
Dec 30, 2008 | Panasonic CT-32HL44 32" TV
Rca model f20352sf
I just read this solution online a few minutes ago, so i don't know how accurate it is, but
someone was having problems viewing DVD. So maybe it will also work for your xbox.
And I quote:
VCR - tune TV to channel 91
DVD - tune TV to channel 92
Someone else posted if these didn't work, try channels 00 or 01.
Hope this helps.
Oct 12, 2008 | RCA F20352SF TV
Hooking up a ps2 to my monitor.
ok " your tv monitor has a remote, look on the remote and push the input button .
also make sure video cable for ps2 is pluged in to the tv video
input plug, female RCA plug should be yellow
Jan 21, 2008 | Polaroid 15'' HDTV Monitor FLM-1511
Televison & Video Logo
540 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
