Question about Compaq Presario 5000 PC Desktop
Computer will not boot
Hi my friends PC (compaq presario)( purchased new 2007 - windows vista) will not boot - When turned on it tries to load windows and then comes up with error message cannot load windows. It then gives you the choice of windows system repair or start windows normally. If you chose the later option it will try to load windows again and bring you back to the same screen. the first option of windows system repair checks the computer for the problem but is unable to find one. In the advanced options there is an option of checking memory and hardware and everything checks out ok. My friend has never backed up and has never created restore points. I told her she could do sysytem recovery but she would then lose her work and photos. As it appears to be a software problem it is not coverd by waranty. This all started after she loaded photos on to the computer. Please help.
    President:
  • 2,351 Answers
Chances are if you load the windows CD into the CD player it wil boot to the CD. You can opt to repair the current version of windows without a format. You will not loose your data.
Posted on Jan 02, 2008
Should I remove Windows Vista on my Compaq Presario Laptop? It is installed as OE but I amm told Microsoft does not support it anymore
For the past few upgrade cycles I have upgraded by purchasing the best value new computers with the OS installed. I connect the old computers to the new via a home network. The newest has Win-7 and is much faster, however, the learning curve is steep getting all the old stuff to work. So for some stuff I still rely on the older machine. This has given me the best results.I still use Vista and XP, but if you feel compelled to upgrade do to security reason I would follow the following outline.
  1. Back up on an external USB drive all important documents. You must do this if not Murphy's rules will apply and it can be a train wreck!!
  2. Down load Acronis from Western Digital website. Make a Boot disk.
  3. Create a clone copy of your master C:/ drive on an external USB drive.
  4. Purchase a same or larger internal PC master C: drive "It must be a Western Digital for the free version of Acronis to work"
  5. Replace current drive with new.
  6. Using Acronis boot disk boot up and connect USB drive
  7. Clone new drive from USB with vista OS using the Acronis boot disk and confirm all is well
  8. You now have a way to go back. Your original drive still has the Vista OS with all your Junk and the new drive should have the same.
  9. Using the new drive go to the Microsoft website and go for OS seven. Keep your clone copy of the vista OS on the USB drive in case the seven blows-up during install.
  10. Retain the original C: drive with the vista OS in case you get into difficulty with the new drive.(mark the drive with date etc)
I have successfully done this for computers and keep a drive loaded with a known good OS for the day it all goes bad.
Sync-toy is the backup program that I use to keep everything up to date.
Hope this helps?
Mar 09, 2016 | Compaq Presario C700 Series Laptop...
Hi, My name is Moses. I own a compaq presario cq 60. It runs on windows vista. At first, everything was working well but now i get the message 'windows failed to start' when i boot. Also, i have a...
Hello friend,Insert DVD labeled vista,and boot from DVD/cd rom
during the installation select repair. On the repair window u can restore your booting files.
try it...
Sep 28, 2010 | Computers & Internet
Compaq Presario c500 - Not booting into Windows Vista Desktop
Try to repair the windows,
use the windows installer and select the repair option to recover the previous windows that was running normally.
Sep 21, 2009 | HP Compaq Presario C500t Notebook
Claification to my problem with compaq pressario
Hi. Azrul here. Here is 2 of my best solution for your problem:
1. Online support from your PC's manufacturer. Restart your PC using a Windows XP/Vista CD and download all the related drivers for your PC online (you will need your compaq presario model number for this)
2. There is also an option to purchase the restore disc online. Depending on the age of the PC that you purchased, just google for "Compaq" or "Hewlett-Packar"and get the restore disk from there.
Dec 21, 2008 | Compaq Presario 5000 PC Desktop
How to disable sata in bios of compaq CQ40 laptops
have an compaq presario cq40-301tu laptop want to load xp already vista is loaded in that while installing xp i get an blue dump error & no setting in bios found to make sata compatible please give me the solution how i can install win xp2-
Nov 27, 2008 | Compaq Presario Notebook
Hi, I have a vista compaq presario 5129, when I turn it on it tries to loead then just freezes. I was wondering if there is a factory reset key to press to restore it back to new, have tried F11 but no...
you can try system restore if your running windows on your computer. try to restart your computer then while waiting for your computer to boot up just try pressing F8 to load under safe mode and look for accessories - system tools- system restore then choose the last good restore point you have.
Nov 09, 2008 | Computers & Internet
Presario f700 drivers
You have to download XP drivers from the manufacturer's website. This normally happens because your harware was designed for the new OS(Vista).
Just go to hp.com and search for the model of your Laptop.
May 20, 2008 | Compaq Presario 700 470024-192 Notebook
Need Help
Last Month i Purchse Laptop Compaq Presario V3702TU With Vista Home Basic. Wrongly I delete the Partition and again I Installed Vista Home Premium down load all Drivers and install only Web Camera Driver not installed kindly help me out how to installed web camera driver on vista home premium 32 bit.
Apr 06, 2008 | Compaq Presario R3000 Notebook
Install xp in compaq presario c700
Dear sir, I purchased a new laptop compaq presario c700. When I tried to install os it is booting from cd but it is not recognising harddisk. I checked in BIOS but I didn't find the option where to find harddisk. So please provivide the solution
Dec 07, 2007 | Compaq Presario C700T Notebook
Compaq presario powers on but dont boot
RE INSTALL YOUR OS (LINUX OR WINDOWS OR VISTA ETC)
Nov 24, 2007 | Compaq Presario 700 470024-192 Notebook
Compaq Presario 5000 PC Desktop Logo
111 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
