Question about Tally T2245 Matrix Printer
Export tally data to excel format
My tally version is Tally 9 Release 1.0, my problum is, how to export my tally data in to excel format. in my tally export option only three option's where occuring that are as follows
1. ASCII
2. HTML and
3. XML
here how can i add excel format in to my tally
  • 23 more comments
  • Anonymous May 26, 2008
    same
  • aniket303 Jun 18, 2008
    i have tally 6.3 my data is exporting in xls format but
    the all colums are coming in one colum i.e. dr. cr. date
    vou. no. amt etc. pl tell be how to do separate coloum
    for separate details
    thanks n regards,
    vrushali
  • satish_time Jun 23, 2008
    want to learn it that how can we get result from tally to excel
  • priyag Jul 18, 2008
    Same problem mentaioned above... how to export tally 9.0 data to xml.
  • madhumathi Aug 18, 2008
    how to export sales and purchase in excell format
  • Anonymous Aug 28, 2008
    Export tally data to excel format problem ?
    pl give me a solution....
  • Anonymous Sep 08, 2008
    i have tally 9 my data is exporting in xls format but
    pvd
  • saravanann vell
    saravanann vell Oct 06, 2008
    i have the same problem please solve this
  • Anonymous Dec 29, 2008
    They all are having the same prob.... since Tally 9.0....
    They all supports uploads to .TXT, .XML, .HTML.....
    There's an upgrade available for Tally 9.0 (Release 2.0)...
    I think, it facilitates exports n uploads to .XSL Format (Excel spreadsheet)
    Plz chkout n inform me if there's another solution fo dat..
    SMG Soft Solutions........
    smg007smg@gmail.com
  • sumipoojari Jan 15, 2009
    how is export tally data to excel formate
  • Anonymous Feb 10, 2009
    tally 7.2 have the same
  • RAMASUVA Feb 24, 2009
    MY TALLY VERSION IS TALLY 7.2 MY PROBLEM IS HOW TO EXPORT MY TALLY DATA TO EXCEL FORMAT in my tally export option only three option's where occuring that are as follows
    1. ASCII
    2. HTML and
    3. XML
  • afsar_wajid2 Feb 28, 2009
    i donot know how to expor tally data in excel.
  • mukthakv Mar 04, 2009
    my tally version is Tally 7.2 Release , my problum is, how to export my tally data in to excel format. in my tally export option only three option's where occuring that are as follows
    1. ASCII
    2. HTML and
    3. XML
    4. SDF
  • arjuntagare Mar 09, 2009
    Please send how Tally data convert excel or Access directly, my email id : arjuntagare@rediffmail.com
  • Anonymous Mar 09, 2009
    how to export data from tally9 to excel sheet
  • pawan_dev Mar 23, 2009
    my tally version is Tally 9 Release 1.0, my problum is, how to export my tally data in to excel format. in my tally export option only three option's where occuring that are as follows
    1. ASCII
    2. HTML and
    3. XML
  • Anonymous Mar 25, 2009
    HOW CAN I EXPORT FROM TALLY VERSION 9
  • Anonymous Apr 06, 2009
  • rawat_rawat2 Apr 07, 2009
    excel formet is not show how can add excel plz
  • varungupta_a Apr 24, 2009
    I cant Export Tally Data in Excel Format
  • kishor_s8 May 11, 2010
    how to convert tally 9.0 data to excel sheet
  • Vikram Jain Oct 23, 2012
    i want to how to convert tally data to any other RDBMS database
  • Nitu Kumari
    Nitu Kumari Mar 19, 2014
    Download Excel to Tally Software - www.xl.nikash.in
  • niranjan adhikari
    niranjan adhikari May 22, 2014
    How to convert tally 5.4 data to excel
Select ASCII. Give output file name Eg:d:/exp Open the file using EXcel.Select Delimite  nexxt comma finish.Export is completed
Posted on Sep 28, 2008
  • solonan5001 Mar 29, 2011
    sir how to excel sheet exports into tally 7.2 or 9.1 please guide me to slove this solution
How tally export to excel format.
Posted on Nov 27, 2008
Hi ,
You can do 2 things , first you could export as text and import it back to excel using the text file you created , secondly you can select HTML and give the file name as eg-XYZ.xls
Regards
Sanjaya
Posted on Oct 28, 2008
  • drpamit Jan 08, 2011
    thanks friend......it works
  • sanjaya72 May 25, 2015
    cheers
Tally 7.2, data export convert to excel direct
Posted on Aug 23, 2010
    New Friend:
1. ASCII
2. HTML and
3. XML
Posted on Dec 25, 2012
Plz give me code how to convert excel to Tally
Posted on Apr 19, 2010
The problems that i've got,
is how to export data in tally 9 to ms excel or how to add new format exporting data in tally 9 such as .xls or any format exporting data
thanks
Posted on Nov 24, 2008
  • surabhi Karpe
    surabhi Karpe Apr 29, 2014
    Please give me a solution
Try using UDIMagic Free Edition to Export Tally data. Download it from http://www.rtslink.com/images/udimagic-free-edition-setup.zip
Posted on Oct 25, 2008
    hii shweta ..thanks friend
  • kalai_tamizh
    kalai_tamizh Sep 05, 2012
    Hi Shweta how to use this UDI I tried but i couldn't find
Learn Tally 7.2, Tally 8.1, Tally 9 @ your home.
Fee Rs.2000 PrePaid (Rs. 500 extra for study material) (weekly 3 days class, 1 hour duration / total 9 class)
Ph : 9341-202004
E-mail : shekhar202004@rediffmail.com
Posted on Feb 07, 2008
For export the data of tally
Command is Alt+E {or mentioned in right side top} after pressing the command, we view options to convert, Now we going top of the viewing page and select in HTML & revolution 1068x720, and click in Y .
After clicking the data is going on the target of tallyies drive
Thanking You!
with warm regards
Abhishek Sharma.
9939112087, 9304821430
Posted on Jun 10, 2009
    New Friend:
Posted on Feb 12, 2013
HOW REMOVE ALL DATA IN TALLY ERP9
Posted on Jun 30, 2011
    New Friend:
Download excel to tally software - www.xl.nikash.in
Posted on Mar 19, 2014
    New Friend:
1] open req. tally data to convert into excel.
2] click on E-export which is situated on left side.
3] click yes on instruction
4] then automatically generate the excel sheet.
Posted on Mar 02, 2013
  • sunil kanojia Mar 02, 2013
    5] try it you vll get beter ans.
    sunil kanojia [9820537771]
Go for release 2 version of Tally 9, where there is provision for data export to excel, check all the features, with help button.
Satish from Nashik
Posted on Jan 02, 2008
3 Suggested Answers
SOURCE: my tally version is Tally 9 Release 1.0, my
whenever you are going to export any tally report into excel then press alt+e then press backspace and the will blink on the status of ascii,html,and xml options popup then choose ascii then choose condensed or deatailed then press enter.then close tally.after closing tally open excel, click file then open then choose c drive where the tally folder is installed then choose all files you see that a notepad is being created then click on it then choose colon semicolon with next and next procedure then it will automatically arrange in excel sheet.
Posted on Feb 27, 2010
Chaudhary G
  • 5 Answers
SOURCE: My tally version is Tally 7.2 my problum is how
Go to 2 Point Html than give the any name of output file (for example sale register.xls) after that you can see your file in exel format.
any problem you may contact me at 09310947557 (Delhi)
Narendra Chaudhary
Posted on Jul 28, 2010
How to export tally 9 to excel sheet
Great question and there are two way export date. Please follow step by step instruction.
  1. In the Balance sheet screen click E : Export or press Alt+E.
  2. Select the required language from the list of Languages displayed.
  3. Select a format from the list of Formats displayed.
  4. By default, the exported file will be stored in C:\Program Files\Tally.ERP 9 for Windows 7 and C:\Tally.ERP 9 for Windows XP operating systems
  5. Press Enter to accept the default Output Filename or type the filename of your choice in order to save the file with a different name.
  6. Press Enter to accept the default Output Sheet Name.
  7. To update the existing file select Yes in Update Existing File.
  8. To format the contents of the file select Yes in Excel (Spreadsheet) formatting.
  9. Select Yes for the Field with Colour, to retain the background colour in the exported file.
And Second:
selecting the ASCII (Comma Delimited) format, the user can export all the reports or data from Tally.ERP 9. The data exported is converted to plain text separated with commas and stored in a file with the extension .txt. This file format is widely used for emailing and used for importing data into another company using Tally.ERP 9
More information please visit this link.
http://www.tallysolutions.com/website/CHM/TallyERP9/Data_Management/Export_Formats.htm
Thanks,
Jun 10, 2014 | HP Office Equipment & Supplies
EXPORT TALLY7.2 DATA INTO EXCEL SPREADSHEET
Please follow the below step for your problem.
Go to Gateway of Tally> Balance Sheet (Here you can choose any report which you want export in tally)
Step 1: In the Balance sheet screen click E: Export or press Alt+E.
Step 2: Select the required language from the list of languages displayed.
Step 3: Select a format from the list of formats displayed.
Step 4: By default, the exported file will be stored in C:\Program files\Tally.ERP 9 for windows 7 and C:\Tally.ERP 9 for windows XP operating systems.
Step 5: Press Enter to accept the default output sheet name.
Step 6: To update the existing file select yes in update existing file.
Step 7: To format the contents of the file selects yes in Excel (Spreadsheet) formatting.
Step 8: Select yes for the filed with color, to retain the background color in the exported file.
Step 9: Accept to export the Balance Sheet to an excel file.
Thanking you
davevipul197
Jun 04, 2011 | Tally T2245 Matrix Printer
The steps to export tally data in excel format?
Please follow the below link for your problem.
http://www.apnitally.com/2007/11/export-data-from-tally-9-to-excel-more.html
you can find your answer in middle of the page.
thanking you
davevipul197
Jan 13, 2011 | Tally T2245 Matrix Printer
How can i export the data tally to excel
There are 2 ways to do it..
Step 1
You can export as text and import it back to excel using the text file you created.
Or
You can select HTML and give the file name as eg-XYZ.xls
Step 2
You can export all reports and statements. For this a separate export button is provided in right hand button bar. To do this go to any report e.g. day book you to export or any statement e.g. balance sheet. You would see export button on top right hand side on button bar. Press it and a screen would pop up with export related options.
The first option is format of data to be exported namely ASCII, HTML, SDF, and XML. Which ever application you are importing this data in would decide in which format you should export the data.
For statements like balance sheets and trial balance which we use to send and import file in word and excel etc. HTML format is good. We need minimum formatting in this format while using it in MS Word and MS Excel.
certain applications accept continuous data where we have defined field length. Then ASCII format is better.
For application which accept SDF and XML format these formats can be chosen.
Give a file name and the exported file is saved in the parent Tally directory on your computer. You can now use that file to import its contents into another program, send it as it is (say if it is HTML file) to a colleague or view it using a browser.
Step 3
Consider exporting day-book.Go to day book press export button or use shot cut key Alt+E. Exporting screen will displayed.
Press Back space on your keyboard. And select Format as ASCII (comma delimited). Now give output File Name as Daybook.csv, now select some other option you want to export from the bottom of the screen.
Press enter to accept screen. Day book is exported in to tally program folder. Check program folder for file daybook.csv,
Double click on it, the file will open in excel program. If you want it in excel work sheet file, use the option Saveas, and save it in Microsoft excel workbook (*.xls) format.
Hope this is helpful. Let us know if the issue is resolved.
*Rating and Comments are invited for this solution
Nov 24, 2010 | Tally T2245 Matrix Printer
My tally version is Tally 7.2 my problum is how to export my tally data in to excel format. In my tally export option only three option's where occuring that are as follows 1. ASCII 2. Html and 3. Xml
Narendra Chaudhary
Jul 07, 2010 | Tally T2245 Matrix Printer
My tally version is Tally 9 Release 1.0, my problum is, how to export my tally data in to excel format. in my tally export option only three option's where occuring that are as follows 1. ASCII 2. HTML and...
Feb 24, 2010 | Tally T2245 Matrix Printer
tally data to excel converting . i have some data export to excel but no excel formating you have some tally data to excel spred sheet software
Aug 27, 2009 | Tally T2245 Matrix Printer
How can i export Tally Data to Excel
when u give the print commant u get an export button on the right side. Press that button and then then selest the rewuired format. XML is the genaralised format used these days. Then import the data in tally
Apr 30, 2009 | Tally T2245 Matrix Printer
Export ledger tally to excell
my name is saurabh yadav
i want to know that how export my sales book ledger export to excell form tally 7.2
Mar 10, 2009 | Tally T2245 Matrix Printer
How can i export tally data to excel format?
Export to Excel With new release now you would get one more options while exporting data. One added format option is Excel format. excelexport.jpgIf you export in this format then file would be saved in xls format. More over if you put Excel formating option to Yes then tally would automatically format the data in presentable format. Tally would automatically bold the headlines and main fields for you and format data in a good way. Take a look at excel snapshot of balance sheet exported from Tally.
excelexport2.jpgThe special thing here is that you can do the calculation on any amount figure or any row or column, which was earlier not possible. The only drawback which i could find was that amount figures are not right aligned which is must for numbers for easy calculation, although you can do it by selecting the amount figures and putting them right aligned.
Feb 27, 2008 | Computers & Internet
Tally T2245 Matrix Printer Logo
26,420 people viewed this question
Top Tally Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
mohamed salim shaikh
Are you a Tally Office Equipment and Supply Expert? Answer questions, earn points and help others
