Question about Foxconn P4M800P7MA-RS2 Motherboard
Memory upgrade from ddr 256mb to ddr2 1g
My mb is foxconn p4m800p7ma, there are slots for ddr and ddr2. i want to change y memory from ddr256mb to ddr2 1g. i removed the ddr256mb then placed the ddr2 1g. but when i tried to open the pc, it didnt open... the ddr2 1g is ok in my other pc with msi motherboard. What shall i do?
  • Naseer Ullah Apr 18, 2008
    i have try to upgrade memory card DDR2 512 to 1G after replace pc is not working no diplay
Foxconn p4m800p7ma support max memory speed 533.if you using 667,it can support.
Posted on May 08, 2008
Mhtml:http://www.foxconnchannel.com/upload/Compatibility/200703291139540676P4M800P7MA-MEM-070212.mht
Posted on Apr 15, 2008
Try Bios settings or jumpers configuration on the motherboard or caracteristics, (read motherboard specifications)
Posted on Jan 03, 2008
  • 2,427 Answers
There is a jumper setting to slect which type of memory you want to use, check your manual for details on how to change it
1> enusre the rams are in correctly
2>ensure your main board supports the amount of memory and the speed of the memory
3> verify jumper select to correct memory type is set correctly
if the main board aint compatable with the memory you brought that will cause the same problem
Posted on Jan 02, 2008
How can I upgrade memory from 256MB?
Check any free memory slots available in the laptop and upgrade the same.
Revert back for assistance.
Jan 20, 2010 | IBM ThinkPad R32 2658 Notebook
I got intel 845 gl motherboard having ddr 256mb pc3200 ram. there are two slots availble. i want to upgrade
If you want to upgrade your ram, buy the same memory frequency like your current ddr 256 mb pc3200 memory. You can upgrade your memory up to 4GB and be sure they have all the same frequency to avoid system complications.
Dec 19, 2009 | Intel Motherboard
Problem With ddr2 (Upgrade From ddr 512mb 400 to ddr2 1gb 800)
If it works fine with one stick of ram. Then it is the ram that is incompatible. You can try different settings but you may end up that the stick isn't compatible. Hope this helps let me know if you have any other questions.
Thank you,
Lee
Nov 05, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Can i upgrade RAM from 533MHZ to 667MHZ for P4M800P7MA?
Please try to upgrade your BIOS, it may solve the issue.
Jan 14, 2009 | Foxconn P4M800P7MA-RS2 Motherboard
Ram upgrade
Its support "DDR SDRAM"
Max Supported Ram is "1GB"/"1024 MB".
Ram Speed: 266 Mhz..
Good luck...
regards,
Dec 04, 2008 | Toshiba Satellite A65-S1068 Notebook
MEMORY UPGRADE FROM DDR 256Mb to DDR2 1GB hangs when Log on/Booting
Its a memory problem obviously. Try dusting the memory slot and try inserting the memory into the slot a couple of times. If still not working, the memory may be incompatible(rarely, there are brands of boards that doesn't suit to certain brands of memory), or it may be damaged.
Sep 27, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
Please help me in my RAM
Hi hope13,
you had it correct the first time. The DDR2 533MHz memory should be in the Blue slots. When using two DIMMS the motherboard requires the DDR2 533MHz memory be of the same size, brand & speed. For you to get a blue screen has nothing to do with you're memory. If there was a problem with you're memory, you bios would let you know by beeping a series of repeating beeps. Blue screens are usually caused by software & some hardware like you're hard drive. If you have data on you're hard drive & you do not want to erase it by re-installing windows fresh (That includes a must format), than I can suggest you download this software from this site. Click on the link.
http://www.ultimatebootcd.com/ Read what the software can do for you. If you do not want the software. Than break out you're windows CD & load it into you're CD-ROM drive. Boot the PC to the CD-ROM drive & in-stall windows. You're PC will function again when you finish installing windows & you're motherboard driver cd.
Good Luck!
I would have posted sooner but I though another was answering you're question.
If I can help you further, feel free to post.
Suggestions & comments welcomed.
Mike
May 14, 2008 | Foxconn P4M800P7MA-RS2 Motherboard
If your PC boots up successfully and load windows then its mean that RAM is working fine... There is some problem with OS settings.. So at XP booting press F8 for start-up menu and select Last known good configuration... Hope it will work...
Please Rate .... Thanks.
May 14, 2008 | Intel Motherboard
Foxconn P4M800P7MA-RS2 Motherboard Logo
646 people viewed this question
Top Foxconn Computers & Internet Experts
Alun Cox
Rommel Balcita
David
David
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
