Question about Rockford Fosgate P3001 Car Audio Amplifier
Rockfordfosgate amp 750s car problem
My inline fuse keeps blowing after afew mins of use.
    Scholar:
  • 67 Answers
If after following solution #1 fuse does not blow you may be overdriving amp into to low impedance (check specs of amp for Impedance limits) Also You may Have low Voltage at amps Power terminals under load causing premature clipping and excessive Current to flow. The higher the Voltage can be held at by using External Caps and High Current Alternator and heavy guage power supply wires the Better amp will perform, Will not clip signal as easy and Current draw may be lower because your not clipping signal. A clipped signal is close to DC and Amp or speaker will eventually fry.
Posted on Jan 11, 2008
  • 631 Answers
Disconnect all speaker wires and RCA cables from the amp. Replace the fuse with a 30 amp fuse and power up the amp. If the fuse blows, the amplifier probably has shorted/leaking output transistors.
Posted on Jan 02, 2008
6ya staff
SOURCE:
1998 Saturn sl1 keeps blowing 30amp cooling fan fuses. it runs for maybe 20 seconds then fuse blows
The cooling fan motor is likely drawing to much current because it is worn out.
May 18, 2016 | Saturn Cars & Trucks
I just replaced an amp and now the inline fuse by the battery keeps blowing
Most likely you have your power and ground connections reversed on the amp. That will cause the fuse to blow immediately upon contacting the two sides of the fuse. If the fuse stays intact for a short while but pops after turning the amp/car on and your connections are correct then there's a problem with the amplifier and it either needs to be serviced or replaced.
Dec 01, 2010 | PPI PC2600 Car Audio Amplifier
What do you do when your amp keeps blowing fuses
First off which fuse is it? The inline fuse from the battery or the amplifiers power supply fuse? Blowing the main fuse from the battery is caused by either the load (your amp) drawing too much current or you have a short to ground somewhere. Maybe there is a tear in the 12Vdc line and it is shorting to the chassis of your car. If the amps power supply fuse is blowing as soon as it turns on your amp has a shorted power supply. This will require internal component changes by a technician. If it is blowing after operation at high volumes I would say change the impedance that the amp is driving. If you are at 2 ohm try to rewire your speakers for four ohm. (go from parallel to series wiring then bridge mono or operate the amp in stereo mode)
Feb 07, 2010 | Infinity Reference 1300a Car Audio...
Automotive wire in line fuse keep blowing fuses
sounds like eithor over draw or short
yes you can over draw the wires
Dec 21, 2009 | LG Art Cool LA1000PR Air Conditioner
Im having trouble i keep blowing fuses on my amp?
you have you gain and freq knobs turned up too far, try turning them down and turn down subb level from deck
Apr 13, 2009 | Rockford Fosgate P3001 Car Audio Amplifier
Fuse
The fuse is an inline located at the back of the radio. Do keep in mind that a fuse blows because there is another prob!! NEVER put in a fuse over the amp rating!!! NEVER Frankster016
Nov 29, 2008 | 2001 Dodge Neon
Fuse keeps blowing
The amplifier probably has shorted output transistors. If the amp only blows the fuse after remote voltage is applied, the damage may be minor. They generally blow two transistors. Sometimes that's all that needs to be replaced.
Let me know if you have any other questions.
Aug 29, 2008 | Jl Audio 500/1 Car Audio Amplifier
Amp problem
you either have a bad ground or your power line is too small, the farther you go from the battery the larger wire you need.
Dec 18, 2007 | Jl Audio 1000/1 Car Audio Amplifier
Wont work
If you were blowing an inline fuse, what size was the fuse and how big did you go up? It's possible the has a short in it.
Sep 26, 2007 | Performance Teknique ICBM-780 Digital...
Rockford Fosgate P3001 Car Audio Amplifier Logo
157 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
Professor_V
Professor_V
Robert Rankin
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
