Hitachi 42V710 42 in. Rear Projection HDTV Television
Problem for Hitachi 42V710 42 in. Rear Projection HDTV Television
I purchased a Sony projection
By orlandaz on Oct 29, 2009
I purchased a Sony projection TV 2002. At this time I noticed there were circular lite and dark blue lines in the background. At this time we got the new FIOS PACKAGE and after the completion, turn on the TV and about five minutes you will see a flashing blue screen in the background, which resulted in the TV shutting off. The timer/standby lite is flashing.
Comments:
Oct 29, 2009
- Great job...
Best Solution
posted on Oct 29, 2009
Very Helpful)
rahul_prasha
Rank: Wiz
Rating: 83%, 188 votes
Disconnect all the cables from the TV including the power cord then reconnect them after a few minutes. Make sure that the power cord from the TV is directly connected to a functional wall outlet.
Also try connecting different video sources to the TV such as DVD player, playstation, etc. to check if the Blue color is visible regardless of the video source connected to the TV.
Furthermore, reset the TV to the original factory settings. Refer to the user manual for the TV to get to know the exact steps to reset the TV to the factory default settings.
if the issue persists even after performing all the above steps then the problem is with the optical block (light engine) of the TV. You may visit the Sony model specific web site to check if Sony is offering any special service program for the TV model for optical block issues.
Solution #2
Somewhat Helpful)
welcomejee
Rank: Guru  Hitachi Televisions & Videos  Expert
Rating: 89%, 3232 votes
I need your Sony TV model number to diagnose problem and its possible solution.
Thanks.
Comments:
Oct 29, 2009
- I asked TV model number of your Sony TV to provide you problem info and possible solution, if any.
Popular Solutions for Hitachi 42V710 42 in. Rear
Questions and Unsolved Problems for Hitachi 42V710 42 in. Rear
Do you recommend Hitachi 42V710 42 in. Rear Projection HDTV Television?
Answer
Answer
everything has a green tint , not able to adjust it away , I replaced a bulb last yr at this time... (More)
Answer
the tv had yellow spots and now there is no more images, we only get the sounds, I wanted to know... (More)
Answer
I replace the lamp which was shattered now the color is horrible.
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
in , PA
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
