Question about Sony Ericsson K750i Cellular Phone
K618i drain energy faster
Please help me to solve this problem,even im not using my fon it keeps on loosing its battery and it can only last 4-5hours,what i am supposed to do? should i replace my battery or what? please help me
  • 425 Answers
Yup! replace your batt... if samething happens after replacing your batt then probably your phone has hardware prob. or short-circuited. hope not... hehehe...
just try replacing your batt...
Posted on Jan 02, 2008
6ya staff
SOURCE:
HTC Dash shutdown help
It seems that ur battary is loose. Insert some packing to fit battary appopriately.
Jan 08, 2012 | T-Mobile Dash Smartphone
My camer charger is not working...... what is the solution for this...... if i connect to computer it is not getting charged why....?
The L10 uses standard AA batteries, either disposable or rechargeable. It does not contain any charging circuitry. Connecting the camera to a computer simply drains the batteries faster, as the camera has to expend energy communicating with the computer (even if only to say it has nothing to say). If you want to use rechargeables, you'll have to charge them using a separate battery charger.
Jan 19, 2011 | Nikon COOLPIX L10 Digital Camera
Battery contstantly drains on 1989 Honda Goldwing Trike 1500
did you start it and put a volt meter on it to verify your getting approx 14 volts to the battery?
May 30, 2009 | 1989 Honda GL 1500 Gold Wing
Canon PowerShot A630 power problem: NiMH batteries no longer work
I dont agree, I have tried several different batterie types and the batteries are draining almost instantly with the camera and they are not actually being drained. I think the camera itself is at the end of its life...as I have used rechargeable batteries for the last few years and now they wont even show as being charged on the camera. It stinks Im in your same spot now...no batteries are lasting even the brand new lithium ones...it has nothing to do with the battery "juice" but something with the canon supply power not recognizing/recieving the juice. Im not a canon expert, but I think the problem is more than the battery here Steve and im confused at the solution as well.
Apr 02, 2009 | Canon PowerShot A630 Digital Camera
My sony ericsson p1i cannot send sms...sms send failed
take out your battery, sim and memory stick.. then turn it off for 5 minutes, then turn in on without inserting the memory stick. after that try sending sms again, if it delivered,then try it with memory stick. if u can send sms,then its ok..but if cant then your memory sticks got a problem.my suggestion is to format the memory stick..
Jan 30, 2009 | Sony Ericsson K618i Cellular Phone
Sony ericsson k850i
Hello there. please try to re-install your phones driver and the next time you insert your phone to your computer use another usb port and not the same you have been using all this while. hope i helped bye!
Jul 11, 2008 | Motorola Mobility W375 Cellular Phone
How to reformat k618i sony ericsson
Hello
You could try doing a master reset but you will lose all data / contacts /pictures/ on your phone
Steps to do a master reset
Settings/general/master reset/reset all/continue
Phone will restart
Jan 03, 2008 | Sony Ericsson K750i Cellular Phone
Camera Draining Battery
Lachuaeyes,
I have a different model of Olympus and I read that you did not always have this problem and you already have replaced the battery so an old battery is not likely the issue. I suspect you might have something that is draining that was not set in the past. I keep my batteries longer by not using flash most of the time. Is there someone new using the camera that perhaps leaves it on longer than you do after finishing, perhaps uses flash longer? Is there a setting for auto shutdown that has been changed to not turn off as fast as it used to? If none of these I wonder if the flash is requiring more energy than in the past.
Could you tell me if the battery is draining even if you don't use it or is it only if you are using it does it drain faster.
Another possibility is that the charger is not charging so well as it used to but I suspect you leave it in long enough and more.
If you have the ability to check the output voltage of the charger with a multimeter you would be sure it is really putting out enough volts to charge fully.
Please let me know if you have further questions.
HarryF
Dec 21, 2007 | Olympus Camedia C-8080 Wide Zoom Digital...
Sony Ericsson K750i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Damen Wong
Damen Wong
Ekse
Zaid Anarwala
Zaid Anarwala
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
