Panasonic PT-50LC13 50 in. Rear Projection HDTV Television
Problem for Panasonic PT-50LC13 50 in. Rear Projection HDTV Television
We have a Panasonic PT-50LC13, the buld died and
By tmoretti on Oct 29, 2009
We have a Panasonic PT-50LC13, the buld died and the unit would no longer light up. We replaced the bulb as noted and the unit still won't light. Do we need to reset something so the unit recognizes a new lamp has been installed? Any help appreciated.
Solution #1
posted on Oct 29, 2009
Not Rated)
kjohnson838
Rank: Apprentice
Rating: 0%, 0 votes
hi I just read that this tv needs a few minutes to warm up i am going to .try it. iam having same problem. i had a tv tech install a bulb and it worked .
but i had a dispute with the tech about the cost of the fix and he took out his bulb and all though i purchased a new housing with bulb in it so that i didn,t have to touch the bulb, when i put it in i got nothing but green to flashing red to yellow. so if my bulb is good and the tech didn't
do something malicous than something has to be reset so that the tv will work because not even the sound of the tv worked.
if you get the ansewr to this please email to kjohnson838@aol.com
Was this helpful?
Yes
No
Popular Solutions for Panasonic PT-50LC13 50 in.
Questions and Unsolved Problems for Panasonic PT-50LC13 50 in.
Do you recommend Panasonic PT-50LC13 50 in. Rear Projection HDTV Television?
Answer
Answer
The TV does not want to turn on. When pushing the button the light stays on for 2 seconds the a red... (More)
Answer
I have a panasonic pt-50lc13 50 in lcd projection tv. It will not turn on... How can i make sure its... (More)
Answer
Is the Panasonic PT50LC13 tv HD readt or do I need to purchase a HD converter box. I tried to... (More)
Answer
When I turn tv on it has great sound but no picture at all. After a couple minutes of the light... (More)
Answer
Panasonic 50" HD TV. Seeing two white circles on screen. Also, on light colors there is a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic PT-50LC13 50 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
