Sony KP-65WS500 65 in. Rear Projection Television
Problem for Sony KP-65WS500 65 in. Rear Projection Television
Sony kp65ws500 color rear video projection tv is
By mcojg5 on Oct 28, 2009
sony kp65ws500 color rear video projection tv is blurry on right and left side clear in center and has a rainbow effect on the sides, any wording is all messed up and almost in like 3d effect with all the colors in the backround
Comments:
Oct 29, 2009
- if you could please send us the general instructions and info on where to get the parts and the grease that is needed that would be great, we live in Lynn, Mass so if you could tell us where we can get the parts to do it ourselves it would really save money we really don't have right now. Thanks for your help
Best Solution
posted on Oct 29, 2009
Very Helpful)
SD Tech
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 97%, 887 votes
If 3D picture one or both of the the STK-392-560 CONVERGENCE IC chips this set uses is bad.
Both chips need to be replaced and any fuses or protect resistors around them as well that are bad need to be replaced.
Some basic facts:
The chips are located usually on the left side as you look from the back on two metal heat sinks with fins.
Each has 18 pins and is bolted to the heat sink. A white grease is applied to the metal back of each chip when it is installed----it transfers heat quickly from the chip to the heat sink--hence the name.
After some years the grease dries out and one of the chips pops and convergence is lost.
Considering the parts for a repair like this are usually under 25 dollars total---if you or someone you know can do it for you---you can save the set and also a lot of money.
I can tell you the best place to buy the parts, tell you if you decide to do it what to look for first, and YES I can give you general instructions for this sets repair.
If you cannot do the repair yourself---shop around your area---most shops charge 300-400 for this type of repair. If they say it "Has to go to the Shop" keep looking as any good tech can do this repair in your home in about 1 hour---------I KNOW, I have done hundreds of them.
If you have learned something from my answer rate this solution---
IF YOU NEED ANY HELP OR ADVICE OR ASSISTANCE LET ME KNOW.
I am here to help people, I do this here for free.
SD TECH
Comments:
Oct 29, 2009
- There is a large company called SUBURBAN ELECTRONICS---you can find their online catalog or go to Ebay----select advanced search, then search by seller: sewsales55 is the same company.THEY ARE IN MARYLAND.
SD TECH
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Sony KP-65WS500 65 in. Rear
Questions and Unsolved Problems for Sony KP-65WS500 65 in. Rear
Do you recommend Sony KP-65WS500 65 in. Rear Projection Television?
Answer
Answer
lines through the picture and when it happens you can hear static through the speakers. there is a... (More)
Answer
How do I get the blue bloches off my tv sreen? It gets worse the longer it stays on...
Answer
My 2005 65" sony rear projection tv picture is now flickering, similiar to watching a bad tape.... (More)
Answer
i have a sony kp-65ws500. the standby light flashes five times when its powered off. the problem... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-65WS500 65 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 735
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
