Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
THE COMBO WHEN YOU HIT PLAY SHOULD BE AUTOMATIC AND DISPLAY PICTURE AND SOUND ON THE SCREEN---THIS IS LISTED AS A TV-VCR COMBO SO IF dvd hooked to one of the rear inputs (some are also on front on some models) in the menu you select that input and should see the picture and hear the sound from the DVD.
this is somtimes a bad power supply or fuse if you have sound it likly and no picture usaly a fuse put this seems pretty much like a power supply issue this regulates power from the wall to each component of the tv like the picture and the souns amp
Our problem was that we could not get picture on the tv screen but it got sound.We tried to solve it using different techniques like the setup,video source,function keys pressed on remote control by trial(only assumed) and error as we could not see the screen and I used scart with every conection but three point pin was free so I put only one pin in video out put and at that moment I could see the picture on tv.
It sounds like the audio cable from the DVD drive may be loose or damaged. Did you wall mount the TV and this is when the problem started or has it always been like this? If its under warranty, contact the helpline on 0871 2000 463, be warned, if its becuase the cable is damaged by a wall mounting screw, its clearly evident and they will charge for repair.
To make region free: * Open the drawer Press 0, 1, 2, 3, Play in sequence on the remote control Play a region 1, 2 ,3 ,4 or any other region to see if the hack has worked!
The disc drawer can obscure the Infra-Red sensor when open, so ensure that you compensate for this when entereing the hack.
You can also return the player to Region 2 only mode using the following sequence:
* Open the drawer * Press ZOOM * Press RETURN * Press POWER
It sounds to me like you have a problem with the reel sensors not detecting movement of the tape through the VCR. This could also be caused by a defective voltage regulator(s) that powers the sensors. This model was made by symphonic/funai (1-800-242-7158), and it is not likely worth repairing.
