Question about Motorola Mobility SLVR L7 Cellular Phone
Ring tone When I receive phone call from the number recorded on phone memory it will not make any Vibration & tone but if I receive call from the number recorded on sim card, this problem will not observed. And I can not charge the phone also
    Brigadier General:
  • 7,752 Answers
Take the phone to a mobile service center and have them fix the issue........with the other problem try and do a master reset on the phone see if that fixs the problem.
Posted on Jan 20, 2008
My phone #1 does not ring nor can I get a dial tone.
Troubleshooting Home Phone for No Dial Tone ' iiHelp
https://iihelp.iinet.net.au/Troubleshooting_Home_Phone_for_No_Dial_T...
This article will explain what to do if you can't make or receive calls using your HomePhone (landline). ... If it rings normally, skip to step 3. If you hear an engaged tone ora recorded voice saying the number is not available, ... If you have a dial tone and can make a call when your phone is plugged into one socket but not ...
No Dial Tone - Phone Forum - Phone Forum - Cox Support Forumsforums.cox.com/forum_home/phone_forum/f/6/t/3496.aspxJan 1, 2014 - 16 posts - ‎13 authorsThis will help determine which phone or jack may be contributing to the problem. If these steps do not restore your phone service it may be necessary to ... directly to the #1 telephone port on the modem and see if you get dial tone there. ... Then try calling yourself(from a cell phone), and as it rings, plug the ...Big Mystery...Phone won't ring ' Techlore
Jan 10, 2016 | Lands Phones
My phone will not ring out loud and vibrate at the same time.
To turn on a ringtone and vibration, go to your BlackBerry's sounds and ring tone options by either of the following ways:
1. Use the trackball to go to the sound icon in the upper left corner of the main screen and click on it, then toward the bottom of the list that appears, select Set Ring Tones/Alerts, then select Phone.
2. In the Home folder, go to your Options folder (usually toward the bottom, has a wrench icon) and select Sounds and Ring Tones.
Select the ring tone and volume that you want, and for Play Sound select Always. Scroll down to Vibration and set it for On.
There is an option for Vibrate with Ring Tone -- set that to on in order to make your phone both ring and vibrate at the same time, then save the settings when you cancel out, and you're all set.
Jun 21, 2010 | RIM BlackBerry? Tour 9630 Smartphone
How do i record something and make it a ring tone
After your sound recording, go to your record folder and then open the recorded sound and then option and set it as a ring tone.
Oct 29, 2009 | LG Vu CU920 Cellular Phone
Ringtone
Unclear if you're using the TMobile ring tones or some that you have downloaded (or created). BION, I got longer ring times by using longer ring tone recordings. (I got mine from free sites on the net, most tones created by people from their music collections.) If you are using ring tones that aren't from T-Mobile, switch to a TM ring tone and see if that makes a difference. (If it does, then shop around for some new ring tones - the old ones were causing a problem.)
Another possibility is to check settings/phone/auto answer. Be sure this is set to "never." Also check Call Barring. Try having your blocking of incoming calls "off."
And last: put profile on "vibrate" and call yourself. Do you get more than one second of vibration? If you don't, then it's probably a phone malfunction, but if you do, it's a ring tone problem. Fairly easy to deal with. Good luck!
Jul 24, 2009 | T-Mobile Dash Smartphone
Can the lg k920 use mp3 from its memory card as a ring tone? its not working with my phone...
dear,
yes, u can ...
check this link
http://www.mobilefun.co.uk/cat/LG-KM900-Arena.htm
or search on google for further...your phone supports mp3 format so that u can get it as ring tone.
regards,
Jul 13, 2009 | Cell Phones
Message Vibration not working
make sure you have "txt messages" set to ring/vibe not "calls to line 1 ring/vibe"
May 29, 2009 | LG Shine KE970 Cellular Phone
How do you turn on vibration for ring tone?
go into profiles. there is a setting for meeting. click on this hit activate and ok. it will set it to vibrate. if you have the three page menu function it is on the second page. you will see outdoor etc. but to set it to vibrate you want the meeting tab.
Apr 05, 2009 | Dual Electronics CECT P168 Cellular Phone
Caller picture and ring tone
Caller Picture:
i) go in the option Phone Book---> Add a New Entry----> To Phone(Not in To Sim)----> you will get all        option such as name, office no, personal no, caller picture, caller video..
 you will get these option only when you store the number or new entry in the phone memory rather than sim memory
                                                            OR
ii) type the number you want store and click the option save and now save in the phone memory rather than the sim memory, you will all option such as name, office no, personal no, caller picture, caller video..
ring tone:
go to memory card or any other place where you ring tone files or song files are present try to highlight it(dont click it) and at the bottom you will 'option' click on it you will get a list of option in that you will have 'set at ring tone' clik on it and you'll be able to set your own ring tone....
Dec 22, 2008 | Dual Electronics CECT P168 Cellular Phone
How to off the vibration of china mobile GSM S6 ? my mobile is named blueTooth plz help me
just press and hold the '#' button for 3 seconds and the vibration mode will be deactivated. :-)
Nov 11, 2008 | Cell Phones
Text vibration alert
Record silence on your phone voice recorder and use that as the alert with vibration on.
Jul 12, 2008 | LG KU990 Viewty
Motorola Mobility SLVR L7 Cellular Phone Logo
27 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
