Question about Spidem Trevi Anthracite Espresso Machine
Gaggia Trevi or Spidem Trevi
The beans are no longer being ground! I have taken it apart and put it back together but still no joy.Im sure its something simple,Any advise.
Regards
JIM(07779 307071)
    Problem Solver:
  • 7 Answers
You may have a legitimate mechanical malfunciton but sometimes the simple solution is the right one! The chute on this (and other) superautomatic does not like the oily residue that beans inevitably leave. All it takes it gently putting one or two fingers into the bean hopper as the grinder motor starts to sound louder/faster (this is caused by the grinder motor being under less load/strain because no beans are feeding) and wiggling for 1-2 seconds. If you do this immediately after hearing the grinder motor's rpms increase you will not get a "fill bean hopper" error messageGaggia Trevi or Spidem Trevi - 2.gif. No hard pushing is required, just a gentle wiggle. There is a shroud over the actual bottom of the hopper, so you don't want to stick your fingers beyond that. If you are concerned about actually sticking your fingers into the hopper while the grinder is running, you can simply push down on the top of the beans with gentle pressure which will in effect force the beans down and accomplish the same thing. This technique + regular cleaning of the grinder may be all you need. Hope this helps! Tony
Posted on Jan 04, 2008
Can I use coffee cleaning tablets with a Spidem trevi digital plus
I would not use this product unless you exactly know what it is, and if it's appropriate for your coffee machine. Instead get some Saeco decalcifier powder DEZCAL that you add to your water and follow your machine instruction on how to decalcify.
Nov 24, 2012 | Saeco Spidem Trevi Digital Plus Fully...
Coffee come out fast and is weak ...
Hi
2 things can cause this.
1. the grind is too coarse. That would be the big knob in the bean hopper. Turn it down when its grinding only. From the factory it is set on 8.
2. The grinder has seperated internaly. That is a tough one to fix, as the grinder should be taken apart and cleaned, then reassembled.
Oct 02, 2010 | Spidem Trevi Digital Plus Coffee Maker
Spidem Trevi Plus coffee is not being dispensed.
The grind chamber is blocked, remove the beans and brew unit then clean the grinds chamber, then adjust the grind 2 numbers coarser and try again.
Nov 05, 2009 | Spidem Trevi Digital Coffee Maker,...
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
Gaggia Trevi will not heat up
check reset buton on tank,or maybe element dont work or computer board
Jul 20, 2009 | Spidem Trevi Anthracite Espresso Machine
No water for brew
Remove the brew group and clean the shower screen at the top. This might be blocked.
Jul 13, 2009 | Spidem Trevi Anthracite Espresso Machine
Spidem trevi digital plus coffee machine not working as it should
it sounds like you need to go into the programing mode. in there you can set the machine so it grinds when you select coffee. at the moment it is pregrinding this is so you can make lots of coffees 1 after the other
Jan 27, 2009 | Spidem Trevi Digital Coffee Maker,...
Spidem Trevi Automatic Coffee Machine
Try to adjust the grinding little finer, when you have adjust this you have to make 3-4 cup of coffee to get the final result.
Jul 03, 2008 | Spidem Trevi Automatic Espresso Machine
Spidem Trevi Anthracite Espresso Machine Logo
490 people viewed this question
Top Spidem Coffee Makers & Espresso Machines Experts
Michael Galve
Michael Galve
Mike
Mike
ray gallant
Are you a Spidem Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
