Samsung HLP4663W 46 in. Rear Projection HDTV Television
Problem for Samsung HLP4663W 46 in. Rear Projection HDTV Television
Replaced color wheel now lamp will not light
By cacfour on Oct 28, 2009
replaced color wheel now lamp will not light
Solution #1
posted on Oct 29, 2009
Somewhat Helpful)
SD Tech
Rank: Guru  Televisions & Videos  Expert
Rating: 97%, 1136 votes
I have a possible solution for you.
When you replaced the color wheel it had two cables that connect into the DMD metal box.
One is a 3 or 4 pin connector with a plug.
The other is a flat ribbon cable usually orange in color.
What sometimes happens here is the ribbon cable only has contacts on one side---same with the socket it slides into.
It is quite possible you got the ribbon cable in backwards---contacts on the ribbon cable not facing or connecting to the socket.
Usually on these sets the socket will have the contacts facing the back of the light engine--
Remove the light engine again and check this out--if you got it in backwards (I did it many years ago the first time I did one) the set will detect the color wheel is not connected and NOT ALLOW THE LAMP TO COME ON.
Lots of videos and instructions on the internet do not tell people about this simple mistake that can be made.
If the set worked before, I bet you got the ribbon cable in backwards---no big deal.......
Let me know if this helps by rating this solution.
I am here to help people, I do this here for free.
SD TECH
Was this helpful?
Yes
No
Popular Solutions for Samsung HLP4663W 46 in. Rear
Questions and Unsolved Problems for Samsung HLP4663W 46 in. Rear
Do you recommend Samsung HLP4663W 46 in. Rear Projection HDTV Television?
Answer
Answer
I have a Samsung LCD 46" TV, only 4 months old. Almost since the beginning, it has emitted a... (More)
Answer
the t.v. will not come on at all. The lamp signal light in the front of the t.v. glows green as if... (More)
Answer
I replaced the lamp and Ballast in my Samsung HLP4663W; still no picture
Answer
I thought it was a fan problem but they both work. If I watch the tv for a while the picture just... (More)
Answer
lost remote and cant turn on tv stays in standby/temp mode
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
