Home | Toshiba | Satellite A300-0CF035 PC Notebook | Have toshiba note boo...
Toshiba Satellite A300-0CF035  PC Notebook
Problem for Toshiba Satellite A300-0CF035 PC Notebook
Have toshiba note book,windows vista opens only in
By gyula_v on Oct 28, 2009
Have toshiba note book,windows vista opens only in safe mode
Solution #1
posted on Oct 29, 2009
Not Rated)
bob_computer
Rank: Guru  Toshiba Computer Hardware  Expert
Rating: 87%, 1192 votes
It may well be some form of virus or spyware.
It may also be that you have too many applications running at once eg. lots of toolbars and instant message typ programs.
It can also happen on graphic intensive applications.
You should rule out nasty stuff first.
MBAM !
for a free one its pretty darned good !
From a CLEAN computer download and put on a flash drive.
Copy to your DESKTOP on the suspec computer.
Run it but dont change any options just use what it offers.
When its done let it clean anything it finds.
Its where I always start with an infected machine.
As for antivirus AVOID Norton or Mcafee but try the AVG FREE version MBAM should clean up without buying
Only continued use would require purchase As for too many applications that would be up to you to decide what you REALLY need and dont. Most toolbars are a waste of both time and space and can hog computers down. Maybe a good clean up is in order ?
It may just be a "leaking application"
These are badly coded programs that dont release memory when they should and just keep taking more to do the same job.
May I suggest you download
"hijackthis"
It is a program that can make a report on what you have running in such a way that you can post that information to certain sites and experts there will look at it.
They will then give you reccomendations as to how you can remove programs or fix some issues that may be upsetting your computer.
Dont post the log here but follow the nstructions and help the program offers to send it to one of the sites it will offer you.
If you understand startup lists you may even be able to spot som things yourself that you dont want to run and disable them from hijack this.
Was this helpful?
Yes
No
Solution #2
posted on Oct 28, 2009
Not Rated)
Pastorwoods3
Rank: Wiz  Computer Hardware  Expert
Rating: 82%, 11 votes
you have a software conflict or a virus you must try a system restore to a preveous date or try to remove conflict in safe mode hope this helps.Install a new antivirus software. Last and i know you dont want to hear this but you may have to reinstall windows on a reformatted hard drive losing all you data.this is worse case.
Was this helpful?
Yes
No
Popular Solutions for Toshiba Satellite A300-0CF035
Questions and Unsolved Problems for Toshiba Satellite A300-0CF035
Do you recommend Toshiba Satellite A300-0CF035 PC Notebook?
Answer
Answer
My webcam is already installed on my laptop but it said that the device is not plugged in, how can I... (More)
Answer
Hi, i have a toshiba laptop model ac300d ,it seems i have a hotkey fault, the FN key does not work... (More)
Answer
Sometimes, the white lights which have all the mute functions and play options, goes dark. When I... (More)
Answer
hii all In laptop toshiba a300 -20t how can play the bluetooth to transfer media fm laptop to my... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba Satellite A300-0CF035 ...:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
