E14 Flame failure: There are obstacles at circulation air inlet or outlet. Fan cage is clogged with dust. Gas pressure dropped when other gas appliances are turned on. (this may also apply to K1 fueled units if you have another K1 based heater)
Here are the rest of the fault codes I found:
Digital Display Reason of indication Trouble Point
E01 At pre-purge, flame rod is sensing flame when there should be none. Flame sensing circuit, grounded flame rod or pinched wire. E05 After power on, power supply to the microprocessor timing circuit is incorrect. Timer clock circuit bad or power cycles (hertz) to unit above or below acceptable levels.
E06 A starting of operation, the circuit to drive photo triac of solenoid pump is malfunctioning. Solenoid pump control circuit has a malfunction.
E08 Revolutions per minute of combustion blower are malfunctioning. Combustion blower or combustion blower control circuit has a malfunction.
E13 No ignition. Failure of ignitor, solenoid pump or circuit board. Incorrect wiring or flame rod touches to burner parts. Air pressure switch or overheat open.
E15 Power supply voltage too low. Voltage too low or power detector circuit has a malfunction.
E16 Load failure of combustion blower motor Flue pipe is restricting air flow.
http://www.keepuswarm.com/upload/M2400OwnersManual.pdf
http://shdashan.com/english/user%20manual%202200.pdf
