Question about Samsung YP-T8 Digital Media Player
Mp3 player not working
I lost my charger and my battery was dead so i found a random phone charger that fit the hole it said it was charging about a half an hour went by and the charg light was off, it was verry hot, i imeditly unpluged it and cooled it down, but it will not turn on its not hot any more i took the cover off of it to see if it smelled fried it dosent, nothing seems to be wrong, but it wont turn on, light up or anything. can you help me its and archos 104 i just got it 2 weeks ago... thanks luv ya ..... katie
  • 3 Answers
You can use the computer conector till u get another one sent out call Samsung on there number sorry i can not be any more help
Posted on Jan 20, 2008
  • thereaperbob Jan 20, 2008
    it is a 5 volt battry
Lost power charger will a telephone charger with the right dc voltage work? jazz hdv188 also its a usb jack in camera instead of the little round holed one
Some phones charge the battery in the camera like a phone, but many do not. The USB connection is meant to be used to transfer photos from the camera to a computer. If your (now lost) charger was plugged into the camera to charge it, and it plugged into the USB connector, then you can charge the camera with any lead that will fit the USB connector, as this will have a standard voltage. You can even charge it from the computer, without buying a separate charger.
However, if your charger charged the batteries outside the phone, by removing them from the phone and placing them in the charger, then it is very unlikely that they will charge in the phone, whatever you connect to it. I have a camera just like this, that requires an external charger.
Oct 29, 2010 | Cameras
Mine isn't a ZEN V Plus but it is a ZEN mp3
it could be the battery that is dead, however it is more likely that the chargers your are trying do not match the voltage needs necessary to charge it. just because a charger fits does not mean that it will actually charge it. LI-ion batteries are VERY picky and some can explode (literally EXPLODE as in bang, where did my hand go) if the wrong voltage is applied. here's the thing, most devices have a fail-safe built into them so that you cannot mess up the battery unfortunately the first charger you tried could have fried this making it unchargeable the reason the other charger works is because when a proper voltage is applied the power is split between running the device and charging the battery (this is cut off if too much power is applied) the actual battery takes very little power to charge you should look up the player via google and take not of the voltage and amperage needed to charge it these are important, there is a good chance it will still work. just buy the proper cable to hook it up to the PC this should charge it however that's not a guarantee the olympus mr100 for instance, would not charge via PC only with the dock and wall adapter. good luck and i hope this helps!
P.S. there is still the possibility that the bat. is fried and you may need a new one.
Apr 14, 2010 | Creative Labs ZEN V Plus MP3 Player
My mp3 go gear wont charge, i've tried to charge it on the ubs port and i've tried to synx it again and nothing is charging it
try getting an old usb phone charger and using that if that wont work then your battery may be dead and its time for a new one
Sep 20, 2009 | Philips PSS110/17 MP3 Player
Doesn't turn on or charger is not working
this has happened to me before. the battery is probably dead. so you so buy a car charger and plug it in and the power should be restored since the car battery is powerful. i did it and it worked easily.
May 06, 2009 | SanDisk Sansa Fuze MP3 Player
Mp3 player shows that battery is dead even though its charged and the screen only works if i hold the on off switch the whole time
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
May 04, 2009 | SanDisk Sansa m240 MP3 Player
Samsung mp3 players YP-T10, I lost the usb charger!
I lost mine as well and after searching the web I found a web site called www.eforcity.com which had the usb chargers. It said it was for the Samsung YP-K3, bu that it is compatible with the T10. It was only $5.99. I am hoping it works when I get it. Good luck!
Apr 08, 2009 | Samsung YP-T10 Digital Media Player
Battery Problems?
Hi all. If you have had your players for some time, and have re-charged them many times over that period (a usual action) then your battery might be near dead.
Most re-chargeable batteries, the longer they are used and re-charged, actually decrease in charged capacity over time.
The only solution, if this *is* the problem, is to fit a new battery. Firms make replacement nw-a3000 etc. batteries for this purpose. I did a google search and found this site:
http://www.batteryupgrade.com/product_detail.php?productId=82781017
There are, I am sure, many more sites which can supply you with what you need!
Jul 30, 2008 | Sony NW-A1000 MP3 Player
Ipod won't charge, won't show up in itunes.
The same thing happened to me. I suggest getting a wall charger? And if your iPod won't show up on iTunes but you want to add songs and stuff, just keep trying.
Jul 25, 2008 | Apple iPod MA446LL/A MP3 Player
Lost my charger
don't ask these people they are ****
Apr 23, 2008 | RCA OPAL M4001 MP3 Player
Mp3 player
Well, charging the battery alot may cause it to malfunction. So you have to charge your battery only when in is near zero (empty), and for no more than 8 hours depending on what device you use. Now your battery is dead, so you got to replace it. Goodluck
Feb 11, 2007 | Neuros (4010100) (128 MB) MP3 Player
Samsung YP-T8 Digital Media Player Logo
60 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
