Posted on Oct 28, 2009
I have a HP 8100 printer, when i print a configuration page, the top half of the sheet prints very light(blurr), while the bottom half of the sheet prints good. At first i thought it was the toner, so i replaced it, the print job is still the same. So i ordered a maintenance kit and replaced the fuser roller etc.. It still prints the same. I tried restoring default factory setting and changed printing quality density, but still no luck. Any Ideas? J
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jul 01, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
154
Points
There is a good chance the laser unit polygonal mirror is dirty. It spins at high speed and the lead edge generally gets dirty. Try removing it with care, cleaning the polygonal mirror and the lens's in the lazer unit
My HP printer prints half on one page and half on another how can i fix it?
Pl share printer model number for better solution.. try this# go to printer menu select default settings..check# check paper size in system..select proper size# un install existing drivers, re install once again..check# print from word or excel format..checkif no result share printer model number... for better solution...Vinay
tip
How to print a configuration page from an HP LaserJet P1102w
The HP LaserJet Professional P1102w is a compact wireless desktop printer. It is very easy to set up and use. Unlike larger HP printers, the P1102w does not even have a true operation panel; it only has a power button, a cancel button, and a wireless button.
However, like just about every other HP printer, the P1102w has the ability to print out a configuration page that displays many of the printer's settings and statistics. This page is called the self test / device configuration page, and on it you can find the printer's page count, number of paper jams (broken down by section), amount of available memory, network settings, and more.
To print the device configuration page, make sure the printer is on and ready. The green light on the top left side of the printer should be lit. If the red light is lit or flashing, then there is a problem with the printer -- such as no toner or a paper jam -- and you won't be able to print the configuration page until the problem is rectified. You'll also need to have at least one sheet of paper loaded into the paper tray. Make sure the two side fences and the rear fence are snug against the paper to prevent misfeeding.
Press and hold the cancel button (the button with the red X on it) for about four seconds. The printer will warm up and begin making noise, and the green light will start to flash -- when these two things happen, you can release the cancel button. The printer will print out the configuration page, face down, and once it has finished the green light will stop flashing and the printer will quiet down.
2helpful
Laserjet 4050 - black streaking on right hand side of page
It is either the toner cartridge or the fuser.
Put paper in the manual feed tray.
Print the Configuration Pages.
When the sheet is half way fed into the printer, open the top cover.
Remove the toner and look at the sheet of paper. If you see the black streak, the toner is bad.
If the sheet looks good, the fuser is bad. Probably a bad roller, which you can see looking at the fuser.
HP 5Si printer, multiple images on one sheet HP 5Si, Windows XP, Networked Jetdirect card, 20MB memory, duplex option. Unit worked fine before. Power outage occurred, seemed to have knocked out the...
If this is a "ghost" image like whats on the top of the page is re-appearing on the middle and/or bottom. The fuser is defective and needs to be replaced. Part # RG5-4447
Getting black streaks along top and bottom edges of paper sheet when duplexing with hp 8100. Prints beautiful if only one-sided.
Issue with the duplexer... could be as simple as cleaning the rollers and things inside the duplexer.. or could be something major like replacing it.
Don't have a definitive answer.. sorry.
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
2helpful
Unable to configure the HP C6380 for double-sided printing
Here is the step by step right from the user manual. also here is a direct link to the manual.
http://h10032.www1.hp.com/ctg/Manual/c01527492.pdf
Let me know how it works out for you.
Print on both sides of the page
You can print two-sided pages with the HP All-in-One manually. When printing two-sided
pages, make sure to use paper that is thick enough so that images do not show through
to the other side.
To print on both sides of the page
1.
Load paper into the input tray.
2. On the File menu in your software application, click Print.
3. Make sure the product is the selected printer.
4. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
5. Click the Features tab.
6. In the Paper saving options area, select Manual from the Two-sided printing dropdown
list.
Perform special print jobs 83
Print
7.
For binding, do one of the following:
• For binding on the top like a notebook or calendar, select the Flip Pages Up check
box.
This causes the odd and even pages of your document to print opposite of each
other top-to-bottom. This ensures that the top of the page is always at the top of
the sheet when you flip the pages up in your bound document.
• For binding on the side like a book or magazine, click to clear the Flip Pages
Up
check box.
other left-to-right. This ensures that the top of the page is always at the top of the
sheet when you turn the pages in your bound document.
3 5 1
8. Click OK, and then click Print or OK in the Print dialog box.
The product begins printing. Wait until all the odd-numbered pages are printed before
removing any of the printed pages from the output tray.
A dialog box displays instructions on the screen when it is time to process the second
side of your job.
9. Click Continue when done.
3helpful
Counter info print out
Hi Beadworker,
This information can be found by printing a configuration page from your printer. Follow these steps to print out a configuration page.
Printing a Configuration Page
You can print a configuration page from the printer’s control
panel. Use the configuration page to view the current settings,
to help troubleshoot problems, or to verify the installation of
optional accessories, such as memory or an optional tray.
To print a configuration page:
1 In ready mode, press the Menu button on the control
panel until you see “Information” on the bottom line of the
display.
2 Press the Enter button to access the menu.
3 Press the Enter button when “Configuration” displays
on the bottom line.
A configuration page prints out.
Poor print quality - top half page okay, bottom print faded and skips top half page okay, bottom print faded and skips problem Just installed a new cartridge
check the wright cartridge model you installed and well pluged to the printer
if it is ok
try to change printer properties and fix it correct options with there tabs ( ex: paper, print quality etc)
all are well try to reinstall the printer driver
Printing only 1/2 the page
print a demo page(which is in the menu)if it comes out ok,it's either the drivers or possibly the formatter board.if demo is not of,it could be the cartridge.i could help you better if i know which half(right to left or top to bottom)
k24674
Grand Canyon Tech
Grand Canyon Tech
