Question about Onkyo TX-SR803 Receiver
Onkyo 805 zone 2 problem
I have an onkyo 805 and setup zone 2 for another room. When I am playing one source in the main zone and a different source in the second zone the sound from zone two lightly comes in on the main zone. Im not sure if it is a setup or if it is a defect. I have been a home theater installer for the last 4 years and never had this problem. Any suggestions?
  • 5 more comments
  • DKong Jan 05, 2008
    I am having the same issue with a brand new Onkyo 705! I have the CD sound coming in on the center channel and sub of the main room setup as well as zone 2, even when I unplug COMPLETELY the center channel speaker from the back. I have no idea what is happening or how to fix--I have a Bose Acoustimass 15 5.1 setup and I can only think of some issue with the preout to the powered sub? This was one of the main reasons I bought it!
  • jimc747 Feb 04, 2008
    recently purchased onkyo 805 and also have zone 2 output problem. have hdmi cables from dvd player to receiver.
    was told to hook up analog cables from dvd to 805 which I did, sound still only comes out of front surround speakers in main room.
    Tried Tuner FM radio on zone 2, same issue, only outputs from front speakers in main room.
    still working with onkyo support to correct.
  • adam81 Oct 23, 2008
    I have an Onkyo 875 and am experiencing the same problem.
    Zone 2 is actively powered and the Front L/R speakers in the main room when it is on. This is true regardless of whether the main zone is on or in standby.
    Did anyone ever get this resolved?
  • tavenger5 Jan 12, 2009
    I'm having a similar issue but with an 806. I can't get anything to come out of zone 2 despite trying the various settings (powered an unpowered). To be specific I have an airport express hooked up to the CD input (RCA). Music plays through the main speakers fine, but nothing at all from zone 2 speakers.
  • Anonymous Mar 17, 2009
    I have the same problem of Zone 2 bleedthrough on rear speakers in main room (5.1 setup). Anyone ever figure this out. I am also a home theater installer and I am baffled. Thanks
  • sierramobile Mar 17, 2009
    same problem as crozell, but with a 606. I have zone 2 bleedthrough on my rear left speaker. have checked everything I can think of with no luck. Thanks
  • Pabster Apr 16, 2009
    Onkly SR606 7.1 - Zone 2, no sound output at all. Tested with RCA output to RCA input speaker, then tested bare wire output to barewire input speaker, read the manual Zone 2 Section several times, but Zone 2 speaker(s) are not putting out any sound. Played with Zone 2 volume and Zone 2 on off button as well. Zone 2 light says its on, but no sound coming through......I am stumped
  • 12 Answers
I just figured out what I was doing wrong last night. On the 806 at least, when zone 2 is not powered (receiver is set to act) there is a separate volume control 'level' that is on the receiver a couple buttons right of the zone 2 button. By default this level appeared to be set to -50db. As soon as I turned up this level sound came out of my zone two.
Posted on Jan 14, 2009
Onkyo zone 2
Is it possible that the currently selected input was changed? Try selecting a different input.
Jan 31, 2014 | Audio Players & Recorders
I cant get my zone 2 to play the same thing as my main tv room, how do i fix the problem?
zone2 does need an analogue signal. If your tv room has an digital source, the zone2 won'tgive the same.
Check the manual, the analogue issue is described.
Rgrds,
Phil
Jan 31, 2011 | Onkyo TX-SR606 Receiver
Denon 1910 Zone 2 no sound
Typically, Zone 2 is for a different program than the one you're hearing in the main listening room. You can choose any source for Zone 2 EXCEPT a digital one.
Dec 29, 2009 | Denon AVR-1803 Receiver
I have the Onkyo HT-S5100, the 5 speaker are set
also, you might have to search through the menu of the receiver, and set the surround back speakers to be zone 2 instead of using the 7.1 configuration that is probably default.
i think zone 2 will only play sources that are hooked up with analog connects, ie. red/white cables. try using the radio to see if it works. you might have to hook up your cable/sat box, cd player, dvd player, whatever you have that you want to listen to with both digital and analog cables to get everything to work right.
Jun 12, 2009 | Onkyo TX-SR503 Receiver
Zone 2 speakers only work with the tuner - no sound comes out when switched to DVD, Cable/SAT, ect. All of my other devices (DVD player, Satellite Receiver, ect.) run through the receiver. How do I get...
hi,
zone 2 will only work with analog sources so if your dvd, cable and other devices are connected via HDMI, that alone won't work. What you need to do is hook up RCA (red and white) cables from the dvd player to dvd in of the receiver and same thing for your satellite box (and other sources.) no need to change any setting on the receiver. This way, the HDMI will take care of your main room speakers and the RCA will feed your zone 2 speakers.
Hope this helps.
Jun 10, 2009 | Onkyo TX-SR605 Receiver
Onkyo 506 zone 2 no sound
I believe that you can only get analog signals thru zone 2 (i.e radio, cassette player), kind of a ripoff since they bury this info in the manual
Jan 03, 2009 | Denon AVR588 Receiver
Onkyo TX-SR805 - surround sound problem
The speaker impedance is not the problem.
Apr 09, 2017 | Onkyo TX-SR803 Receiver
Can't get Zone 2 output
are you useing an onkyo amp?Iff so tell the amp to switch on zone 2 then set the volume for that zone and the source you want to play.
Apr 22, 2008 | Denon AVR-3805 Receiver
Onkyo Zone 2 problem
The zone 2 will only play analog sources - so  you must hook up the output from the tv/cable/dss on it's analog (RCA Jacks) into an input on the Onkyo.  You might also have to enable this output from you tv/cable/dss.
Mar 25, 2007 | Onkyo TX-SR700 Receiver
Onkyo TX-SR803 Receiver Logo
2,691 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
