Question about Norcent Technologies LT-2722 27 in. LCD Television
Norcent LT2723 PC Parameters
Got my LCD connected to the PC via analog cable (15pin). Problem is, I can't even access the PC parameters off of the menu from the TV. I've tried selecting different inputs from the Main Source when I pressed the TV/Video button but I can't still see my PC desktop showing.
Any help is highly appreciated....
  • walker127 Jan 02, 2008
    I have connected my Laptop to my TV but the TV doesn't recognise anything is plugged in so I can't select it. However the PC recognises there is an additional monitor.
    The TV works ok with the dvd.
Had the same problem on my norcent 2722 too. Change your PC resolution to 1280 x 720 pixels and try the inputs again.
Posted on Mar 28, 2008
Hi, I have KEB 07.f5.c1b-3b0a inverter. I just got
Via Combivis, write a value of -4 to Fr.01. This will set all parameters back to the factory default values.
Then download your backup parameter file.
Sep 24, 2013 | Inverter KEB COMBIVERT F5
How to set keb f5 compact to work with analog input wich parameters must be set and what is position on x2 that start the inverter
Please see link below for instruction manual.
F5 G/C/B manual
Basic default functionality of the inverter out of the box is to run via analog input.
Jun 07, 2011 | Inverter KEB COMBIVERT F5
How can i communicate from my pc to the ups on the 9 pin serial connection
Taken from the MGE UPS SYSTEMS, Network Management Card Installation manual (34003641EN/AD)
Run Hyper Terminal on a PC running Windows (9x, Me, NT4.0, 2000 or
Connect the card to the PC using the cable supplied.
Set up the terminal with the following communication parameters:
9600 bauds. 8 data bits.
1 stop bit. no parity.
no flow control.
ASCII: "echo typed characters locally" option disabled.
Press the Carriage return key. The configuration menu is displayed.
Enter the password (MGEUPS by default).
The main menu is displayed.
Select one of the items in the configuration menu.
Via the serial link or Telnet
Select the "Agent configuration" command by entering 1.
Select the item numbers and modify all the IP parameters (address, mask, gateway).
Once all the modifications have been made, exit following the instructions on the screen.
Restarting the card Via the serial link or Telnet
Select the "Restart agent" command by entering 6.
Then follow the instructions on the screen.
Restoring the default parameters Via Telnet or Hyper Terminal
Select the "Reset configuration to default" command by entering 5.
Nov 05, 2010 | MGE UPS Galaxy 3000 UPS System
I connected via scart/component cable to my vsx-2020. i don't get any picture. the sound is ok. i connected it via en optical cable for the digital sound and rca cables for the analog sound. what shall i...
I had the same sort of problem with my DVD player. I tried another one and it worked for both video and audio so I concluded the old DVD had bitten the dust. Make sure you hook up the other DVD (that works) in the same manner as the one that doesn't work so you limit the parameters to whether the old one works or not.
Nov 03, 2010 | Pioneer DVL-909 DVD Player
My asus Eeepc 1005HA has Linux and Windows XP. i can connect to internet via Linux but not Via Windows XP either Wireless or Etherness. I tried two other laptop and both of them connected to internet my...
Make sure that the drivers for both the NIC (ethernet) and wireless are installed. Then you will need to reset the TCP/IP.
In Windows XP click on the start menu and then click on Run. In the box type cmd and hit the enter key. A command window will open up. type in the window netsh int ip reset c:\resetlog.txt and hit enter.
2 new registry keys will be wrote in the registy >>>>>>>
Reboot the Windows OS and hopefully you can then access the net via both types of connections.
Mar 08, 2010 | ASUS Eee 4G Notebook
I want to connect a new HP laptop to my LAN. There is/was a laptop using my internet connection via a router which is still active (router) but the old HP laptop died.
In the control panel network setting, connect using 'connect to a workplace'. Ofcourse with a LAN cable, insert one end of the cable to the pc as well as the other to the router. Put in the usual parameters.
Mar 03, 2010 | HP Computers & Internet
My name is rall i have a siemens micromaster ac drive .37kw single phase and it working with one siemens plc s7 ,plc send analoge signal (4-20ma) to it for running but it dosent run. but in local mode its...
jst chk out the connection of the plc and find that the resistence of 500 ohms linked with 10v which converts 10v to 4-20ma is working if it is then it will work or check the drive's connection n parameters of P1300 & communication parameters
Dec 13, 2009 | Inverter Siemens Micromaster 440
Have acer aspire netbook. what cable do I need to hook up to LCD?
Do you want to connect an external LCD screen to your Acer laptop?
The Acer will have a blue 15pin Dsub female video connector. The standard 15pin monitor video cable will connect to the Acer's video port.
Sep 27, 2009 | Acer Aspire One PC Notebook
Failed to get boot parameters via DHCP
You didn't provide any information about your network which is ALWAYS required to provide any type of help, not to mention a solution.
"Failed to get boot parameters via DHCP, xxx seconds until reboot" simply means that the computer isn't getting an IP address from your router. Setting up your router is another entirely separate topic.
This is pretty simple though, one of three things is happening:
1. Your router is not properly configured to provide DHCP to the phone.
2. Your network cable is bad.
3. Your phone is bad (most likely the RJ45 port since the phone seems to work otherwise).
You can check for bad ports or cables by checking the port status within the router. If the port is lit up, most likely the cable and phone port are fine. This is not 100% though, replacing the cable should always be a consideration even with a lit port.
Apr 10, 2009 | Polycom SoundPoint IP 501 IP Phone
Norcent tv model lt2722
I'm Looking for a remote for the Norcent LCD TV model number lt2723? My Norcent will run for 10 minute and turn off so I would have to unplug it to get it back on for another 10 minute is there a sleep timer on this unit? I think that the remote will have that mode.
Oct 27, 2008 | Norcent Technologies LT-2722 27 in. LCD...
Norcent Technologies LT-2722 27 in. LCD Television Logo
168 people viewed this question
Top Norcent Technologies Televison & Video Experts
Computer Repairing
Computer Repairing
Jaime Hernandez
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
