Question about Celestion 1525E Coaxial Car Speaker
Celestion QXa 152 PA speakers
Hi one of my speakers Celestion Qxa 152 (powered)was working fine however my 2 year old daughter managed to flick a switch at the back of it which has up the top 230v and at the bottom 115v while the speaker was still on and now i dont seem to be getting any power thru it...
Please tell me she hasnt distroyed it????
Thanks Dee
Ps where can i find an owners manual
  • 749 Answers
Well, if you can manage to open it and check for a "blown fuse" and change a good one... if it works ... you are lucky. I'll hope and pray that it's only the FUSE.
Posted on Jan 02, 2008
6ya staff
SOURCE:
Kenwood dishwasher when we switch on display comes on for couple of seconds then goes off apart from 3 bars on front
Hi Patrick, did you manage to resolve your issue. I have a 2 year old Kenwood Slimline 45S13. When I press "power", the program options flick on for less than a second, and then the display goes blank. Thanks and good luck. Francis
Mar 28, 2017 | Kenwood Dishwashers
Replacement tweeters
TIP
Why not go for replacement diaphragms for the ones you have ?
Its not realy difficult to do it yourself
celestion a2 tweeter blown or not
http://reconingspeakers.com/product-category/diaphragms/celestion-diaphragms
Jul 26, 2013 | Celestion A2 Speaker
My celestion s20 subwoofer won't play if i hook it up to sub out on receiver.but will play if i run a regular speaker wire to it. I know sub out is working on receiver.
Tell your source (receiver???) that it has a sub and set it up to feed LFE out of that RCA jack.
Prove your sub pre-out works. Or send something like FM on Tape Out to the sub and see how that works out.
How did you hook a speaker wire to this model of powered sub? What was on the other end of that speaker wire? It's not designed for speaker level input.
Jan 28, 2011 | Celestion S20 Subwoofer
The sound from my home stereo sounds muffled. I checked for loose wires but did not find any. I have Celestion 15 speakers - they are about fifteen years old.
Muffled sound? Like no treble? Wires wouldn't cause it. Could be bad tweeters.
More specific details re: electronics, source(s) might help.
Jan 15, 2011 | Audio Players & Recorders
Celestion g12l
I think that one reason for a speaker to rub is due to over heating of the voice coil. This happens when power is applied to the speaker that is greater than the speaker is capable of handling. A second cause could be that the suspension and or cone is damaged or degraded causing the coil to be tilted or off center. In either case nothing short of rebuilding the speaker can be done to repair the speaker. Rebuilding would involve removing the cone and voice coil and replacing with new items. If you were talented you might be able to repair the existing cone or voice coil but the results could be iffy.
Sep 08, 2008 | Celestion 20i Speaker
Tweeters poked to death
I know this sounds silly, but I had the same problem. Your speakers have a little plastic bulb that has been pushed in, right?
If so, simply put your mouth up to the tweeter, seal with your lips and **** gently (seriously). The tweeter dome should pop back out and in to shape.
It worked for me.
Good luck.
Aug 03, 2008 | Celestion AVF302 Main / Stereo Speaker
Pc connection
yes,,,i think it will on run 2 speakers,,, get y cables
Jul 11, 2008 | Celestion S10 Subwoofer
Klipsh Promedia 2.1
I was face the same problem 2 year's ago.This problem occur when you move the speaker's here and there.at that time speaker's wire diconnected in inside...please check the whole wire by electricians for where exactly it is disconnected...
Sep 10, 2006 | HP ProMedia Computer Speakers
Celestion S8 Subwoofer
I would check the electroltyc caps in the power supply They general are in the first part of the power supply and there will be two of them . What they do is filter out transformer hum and help stabalize the circuit. I am not saying this is absolutely the problem but the capcitors are relatively inexpensive, Easy to change. And have a habit of going bad after a couple of years in use.
Aug 22, 2006 | Celestion S8 Subwoofer
Celestion 1525E Coaxial Car Speaker Logo
301 people viewed this question
Top Celestion Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Celestion Car Audio and Video Expert? Answer questions, earn points and help others
