brushes wotn spin,belt not broken,cog that drives the belt is not spinning.When I turn the brushes...
(More)
brushes wotn spin,belt not broken,cog that drives the belt is not spinning.When I turn the brushes manually I can occaisionally feel it grabbing for a a brief second.Could the motor be bad? Is there a way to test the motor.Tahnks
In the process of cleaning the lint guard of the clean water tank cap & insert, the assembly...
(More)
In the process of cleaning the lint guard of the clean water tank cap & insert, the assembly fell out. There is a black plastic post, 1 metal spring, 1 metal washer and a rubber seal. I have tried to assemble them various ways, but only one way will 'lock' into place and water will leak. The other configurations won't even lock in place. Could someone please tell me how these four parts assemble?
I have a Bissell proheat 2x and it leaks water around the wheel area and drains the solution tank...
(More)
I have a Bissell proheat 2x and it leaks water around the wheel area and drains the solution tank quickly.
