Home | Dell | E173FP 17" LCD Monitor | Dell AS500 screen cut...
Dell E173FP 17" LCD Monitor
Problem for Dell E173FP 17" LCD Monitor
Dell AS500 screen cut off before login
By maryh_3 on Oct 28, 2009
dell AS500 screen cut off before login
Clarification Request
Posted by 12fixlouie on Oct 29, 2009
maryh_3, If it was working ok before it should be ok today. Dell didn't make a AS500 computer monitor. LOOK on back of the monitor for correct mod# . AS500 is some sort of audio option!!! Test the monitor. When you say "screen cut off before login" did you mean that you tried to login LATE and that if you had arrived sooner you could have logged in? Try to do this test. Reconnect your Dell to a KNOWN GOOD, fully booted pc that has the win-desktop as the displayed window. Make note of EXACTLY what takes place on LCD panel when you push the "on/off" front panel switch of the monitor to turn it on. How long were you able to see the desktop on the LCD panel? 1 sec or 2 sec, 3sec or 48.5 seconds? Did the screen turn DARK? Or did the screen go BLACK but not BLANK? or did it turn BLACK and BLANK??? Hold a very bright flashlight at different angles, 1" from the screen and even though the LCD panel looks BLACK you may still be able to see the desktop if the monitor's power supply (switch-mode-power-supply) is in partial SHUTDOWN mode. If you don't see a very faint image of the desktop then the SMPS will be in full SHUTDOWN mode. Mary, get back to fixya with your results from doing the flashlight "trick" that every owner of an LCD monitor with CCFlamps should know how to do when the "BLACK SCREEN OF DEATH" darkens their LCD panel. If your screen was bright 2 or 3 days before, then you should think about getting it repaired or contact Dell and ask about a cash+old for a factory refurbished unit. Here is what might happen if you "trade-in" your unit for for a new wide screen unit. Let's just guess that the sales guy gives you $5 or $10 for your monitor. The Tech in the back gives him $5 for it and proceeds to repair it, and if lucky puts $2 to $5 in parts into your old unit. The Tech now has a nice monitor he can sell off to one of his friends for $40-$60. Well anyway, get back to fixya and let us know what your plan of action will be. I hope that this response was of some help to you. You may also want to visit www.ccl-la.com/badcaps.htm and www.badcaps.net , www.lcdparts.net just to find out what causes some LCD monitors to fail after only 2-3 years use. Please rate this response on fixya if you can.. I'm 12fix louie Bye for now.
Popular Solutions for Dell E173FP 17" LCD Monitor
Questions and Unsolved Problems for Dell E173FP 17" LCD Monitor
Do you recommend Dell E173FP 17" LCD Monitor?
Answer
Answer
it flickers on and off,button goes amber and green.
Answer
ghosting on everything on the screen. Everything looks like it has been smudged to the right.
Answer
How to connect, out 6 pins S-video to TV scart ?
Answer
E173FP 17" LCD Monitor when turned on goes as far as loading wallpaper then blanks out and Will... (More)
Answer
have dual monitors, but when moving stuff from primary to secondary screen i have to drag it from... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell E173FP 17" LCD Monitor:
Top Monitor Experts
Rank: Guru Guru
Solutions: 712
Experience: 30 Years of professional repair and design.
Ask Me
Find more Monitor Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
