Question about Biostar M7VKG Motherboard
Front panel connection
I cant seem to find right connection for the power led hdd led? the board was m7vkg
  • drew08 Aug 10, 2008
    i cant find the right connection of HDD led and power led on my m7vkg M-board
    Scholar:
  • 131 Answers
Download the manual from this link ftp://ftp.biostar-usa.com/manuals/M7VKG/M7VKGmanual.pdf go the chapter 1.3.1 you have the front panel connection diagram there as JPANEL2 give the connections as the manual says.
Posted on Jan 02, 2008
Cant seem to get right the pin connection on the morther board for power,hdd.
One corner of the motherboard will have a grid of pins.
Two adjacent pins will be labelled 'PWR' or 'POWER'.
Two adjacent pins will be labelled 'HD' or 'HDD' or 'HD LED'.
Dec 20, 2010 | Computers & Internet
I have 3 wires on my pc and i dont know where to connect them on my motherbaord - the wires have writen on them "HDD LED" "PWR LED" "PWR S/W" can any1 help me?
Hi Dan,
The wires are from the front panel. HDD LED which causes an led (usually red) light to turn on when the Hard Drive is active. The PWR LED turns on an LED light (usually green) when you turn on your computer. The PWR S/W turns on your computer when you press the on button of your computer. The front panel connector riser is usually located on the bottom right of your computer. They fit on little pins. Unfortunately there is no standard, so connections vary. Sometimes the pins are labeled on the motherboard. . Check your manual. For more info do a google search for "Motherboard front panel connectors". Hank
Mar 12, 2010 | Intel Computers & Internet
I have just gotten a new PC case, but can't find the pwr conn.
The front panel connector is close to the SATA connectors. If you look real close (as in flashlight and magnifying glass) at the printing on the motherboard, you will see "pwr_led", "pwrsw", "hdd led", and "reset" printed on the board. Just match what it says on the wires to what it says on the board. Polarity only matters with the LED's. If they don't work, just swap the leads.
Here is the manual for that mobo:
http://www.foxconnchannel.com/support/downloads_detail.aspx?ID=en-us0001142
Dec 31, 2009 | Computers & Internet
I need the front panel pinout for an Emachine T2984 motherboard
Here is the pinout for several Intel MB's with 845GV Chipset.
Mar 18, 2009 | Intel Computers & Internet
CAN YOU TELL ME HOW TO CONNECT WIRE FROM MOTHERBOARD TO FRONT PANEL?
When you say wire, I assume you meant the wires connecting those LED lights at the front of the panel. If you look closely in the motherboard, there is a small 9 pin plug at the side of the board and beside it says front pnl. One row has 5 pins and the second row with 4 pins. These pins are for the on/off button, power on led light, Hdd light and the reset button. All the plugs are marked, HDD, Reset etc. You have to try by error to find the right pin for the right plug Sirjohn
Mar 16, 2009 | Intel Desktop Board D845WN Motherboard
I cant get the HDD LED to work... yes it is hooked up right...
Some of the wires going from the power switch, reset switch, speaker, and LEDs must be attached to the motherboard the correct way. That is, they must not only be placed in the right spot where they need to go, but they also must be connected with positive and negative wires on the right pins.
If your HDD LED is not lighting up when the HDD is "thinking", try reversing the cable where the HDD LED wire plugs in (just flip it so the black wire is where the non-black wire was). I tried to find a good picture of your motherboard to guide you but they were not very helpful. From squinting really hard, I believe the spot they should plug into the board is by the CMOS battery. There might be printed words on the board surrounding the area to connect them that tells you which two pins are for the HDD LED.
Mar 03, 2009 | Gateway (4000782) Motherboard
Front pannel header
if you have retsart / on - off and hdd led thats all you need to run the pc leave the others off.
hope this helps
Jan 03, 2009 | Intel Desktop Board D865GBF (MBIND865GBF)...
Hdd led off
see to the front panel section on mother board possibly on the right hand side of bottom u can see the label there to connect hdd led
Dec 28, 2008 | MSI RS480M-IL (816909008517) Motherboard
Connecting hdd led lead and power led lead,where do they go ?
Hi, There are 3 versions of this motherboard; 1.0, 2.0 & 3.3, but the layout is identical. The general layout is shown in pins.jpg. For the power led, the white wire goes to the (-) terminal either pin 2 or 3, both are MPD- while the green goes to the ( ) or pin 1 (MPD ) as shown in powerled.jpg HDDpins.jpg shows the connection of HDD led, the white goes to pin 3 or HD- while the red goes to pin 1 or the HDD . I cropped these images from the manual which is also available at the gigabyte website. Hope this gives you some ideas and workout of you. Good luck and pls post again how things turn up. Kind regards.
Aug 15, 2007 | Gigabyte GA-965G-DS3 Motherboard
Biostar M7VKG Motherboard Logo
178 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Alun Cox
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
