LG Intello Washer DD 7Kg. WD-1460FHD
Ever since I have purchased the above washing machine I continually have this machine walking across the floor from vibration as a result of an unbalanced load. I have continually leveled the machine with a spirit level, but still dances across the floor. Otherwise the machine works perfectly, washes cleanly. Only black marks from the rubber feet across the floor. Any solutions would be greatly appreciated.
Regards
[email protected]
  • mooseu12 Aug 11, 2008
    Our new LG front load washer is walking across the floor. What are the packing bolts some are talking about removing. Please help with a solution to this problem
Try getting hold of new feet for the machine They generally come with plastic or rubber feet. If you can get ceramic feet they will hold to the floor better and create a suction which will prevent it from walking. I had the same troube and i had some one to look at my machine, they got me ceramic feet and problem solved. good luck
Posted on Nov 01, 2008
    President:
  • 1,314 Answers
Did you remove the shipping bolts before you starting using it consult your owners manual under installation for location and removal procedures all washers have them to stabilize them during shipping
Posted on Jan 02, 2008
6ya staff
SOURCE:
Lg intellowashet DD 7kg WD-1412RD. Won't start sometimes
it appears this type of washer is "sensing" what it may have inside of its self some washers will do this in this model type but if it fails it maybe a sensor not working as it should if its throwing an error code on its display
Sep 12, 2016 | LG Washing Machines
I need an instruction manual for LG Intello Wash 7kg WD 8013C
Sorry but this forum does not supply any type of manual direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 16, 2011 | LG Washing Machines
My LG 7kg frontloader intellowasher WD8013F is leaking from underneath and no water is going into the washing machine. Please help?
i removed the filter off the front of my lg intello washer to clean and now it keeps leaking water from the filter what have i done ?
Jul 12, 2010 | LG Washing Machines
LG-INTELLO WASHER 7kg WD-8074FHB
"de" means door is open you have to close the door titly then press the start bottom or check door switch if its out of order or not with digital multi meter.
Apr 10, 2010 | LG WM1812C Front Load Washer
Vibrates then starts walking across floor
LG washing machines are very finicky with being leveled, they must be 100% level, and squared up on all sides. Be sure to lock the nuts in place, once you level it, to where it needs to be. They are also finicky with certain floor surfaces, more leveling may be required.
Mar 30, 2010 | LG WD-16115FD Front Load Washer
It showing cl on the screen
Hi
Thanks for using FixYa. CL means child lock, it might have got locked. Try pressing "dry" & "spin" together for a 10 seconds or until the CL disappears. Also try pressing "end of cycle" for over 5 seconds.
If this doesn't work then try pressing "options & select" till the light goes off.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Nov 12, 2009 | LG Washing Machines
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG Intello wm-1460FHD stops spinning during the wash load.
OE is a drain error (indicating the machine has not drained out in under 10 minutes). If the drain pump is not coming on at all then you have a bad drain pump motor. If it is trying to drain then you may have a clogged up drain hose. The most likely cause is a bad drain pump motor. Hope this helps.
Jan 11, 2009 | LG WM-1480FHD Front Load Washer
Washing Machines Logo
1,258 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
