Canon PIXMA MP780 All-In-One InkJet Printer
PIXMA MP780 - not printing black chararcters
shared by 8 users
posted by Piet L on Jan 02, 2008
Hi - I loaded new cartridges 12mths ago and did not use. Today I set it up again only to find that when I print it will print the background graphics (in colour) nicely but will not print ant text? I then replaced the old black cartridges ((6 and 3e BK) and it made no difference.
I cannot print any black text?
Appreciate your help.
thanks Pieter
Comment posted on Jan 06, 2008
I was advised top soak the print head in turpentine for an hour and dry overnight.
I can confirm if you do this it destroys the print head unit ie all the rubber rings dislodge and the solonoid/chip unit detaches also.
My question is - it is worth replacing the printer head (and if yes, where can I buy it?) and if so will it work? Or is it a new boat anchor?
regards, Pieter
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
7 Other Users Have The Same Problem
Posted by Guest on Sep 09, 2008
The cleaning and deep cleaning does not seem to be cleaning the nozzle I have to print on High to have even a light print. What do I do next?
Posted by Guest on May 04, 2008
Same problem. Will not print in black. Colour is fine. Yorky
Posted by stuarts2 on May 01, 2008
Same problem here. My printer prints everything but black.
Posted by Chalupa on Feb 14, 2008
I have the same problem - suddenly no black. Cleaned heads, called canon tech support - they advised getting a new head - replaced head, same problem, it still does not print - WEAK
Posted by Guest on Feb 09, 2008
I am having the same problem with my printer not printing black, this has been a great printer up to this point, we moved recently and I do not have the disc to reinstall. What can I do?
rbiest@myclearwave.net
Best Solution
posted on Feb 06, 2008
Helpful (85)
Ferrets
Rank:Apprentice Apprentice
Rating: 89%, 4 votes
About a month ago my Pixma MP780 suddenly stopped printing the 3e black as well. Did some research & wound up calling Canon tech support. They advised me that there was an 80% chance that the problem would be fixed by buying a new $50 print head. Against my better judgement, I purchased & installed it. (I liked the printer & am biding my time for color laser multifunctions to come down)
To make a long story short - if your problem ocurrs from one day to the next - it is not likely to be caused by bad ink, "non OEM ink" or clogged heads etc.
I think the black head driver IC is shot - seems to be a very common problem - just like canon's E18 error - which I was burnt by as well.
So I'm looking at the MF8180C
Anyone want to buy a almost new print head ?????
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on PIXMA MP780 - not printing black chararcters:
I don't want to Accept this solution
Solution #2
posted on Jan 02, 2008
Thanks for Trying (70)
Soulvisitor
Rank:Guru Guru
Rating: 88%, 1566 votes
Print head is a user replaceable part like inks, clicks out replace it.
INFO link
Comment by Kobber, posted on Jan 04, 2008 Our MP780 will not print at all. Other functions working. have replaced all the cartridges and also a new Print Head.
Any suggestions?
Clean print head connections, must run a few cleans to prime new head!!
After Installing your Printhead
You may need to perform a head cleaning routine after installation and the print head will need to be re-aligned, refer to your user manual on how to do this
Read instructions, use only real canon ink to prime it!
No it is probally not worth repairing any inkjet printer it is more economical to buy new with warrenty and new consumables
Whats with rating Pieter
You didn't even buy a new head as I suggested
You followed not my advice in along shot but you rate me (who is helping you) for your mistake. Peolpe just love to vent their own frustrations at others.
Cheers Mate!
Link to purchase head
Comment posted on Jan 07, 2008
Comment posted on Jan 08, 2008
I just finished fixing another of these that makes about 20 in all.
This customers complaint, can't do head alignment, the reason couldn't print with 6BK.
All I did once again was replace the two non genuine inks the customer had installed with the proper canon item, tested it, made no difference cause crap ink had blocked head, so then a new canon print head was put in, ran an alignment, picture perfect!
Customer was advised not to give printer any more injections
Fix is Replace any non Canon or old inks, test, if auto head alignment still fails, then buy a new head and fit it, run a alignment, if it fails run a couple of cleans, try alignment again, if it fails, clean contacts, test.
My bet is everyone of the posters here have not in fact replaced ink with Canon product, they have changed crappy ink with crappy ink that they get cheap or have not replaced head at all.
I just cant see any other possibility except maybe if you have been using crap ink, it has leaked and damaged head contacts.
P.S. I am not a employee of canon, just telling what is seen in a printers workshop, all brands of machines end up stuffed cause of inferior products fed to them. Wake up recyclers you are filling the world with wrecked machines.
Rating Locked! (?) Piet L has rated this solution as Thanks for Trying
Thank You!
Solution #3
posted on Apr 27, 2008
Not Rated (0)
hofmk
Rating: 0%, 0 votes
I have had this problem on 2 of these printers. With much patience, I have been able to solve it by repeated cleanings including print head alignment, followed by turning off the maching for an extended period of time (preferrably a couple of hours), then cleaning again. After repeating this process, I finally got the black to partially print, then repeated the process again and it finally worked!!! Hooray!!!
Thank You!
Can you Help with these Printers problems?
Canon pixma mp780 keeps telling me to load paper and press...
The black text was acting strangely - every other line,...
My printer is a HP Photosmart C5180, When I replaced one...
Although my ink levels show that I have plenty of ink, the...
Im looking at picking up a very cheap canon canner, it is...
7 Other Users Have The Same Problem - Continued
Any suggestions?
Thankyou
Roz
Comment by sh1tty, posted on Jan 03, 2008
What was the outcome here? Did you replace the item as mentioned in the reply?
I replaced all cartridges in my MP780 (the 6Cyan, 6Magenta, 6Yellow and 6 Black) but the Black 3ek cartridge still reports as half full, so I didnt replace it.
I cant print anything in black either. Color is perfect. Color text is perfect. Just black does not work. I even used Canon cartridges.
Any clues?
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Help us help you.
Take a brief survey and help us improve the site.
Your opinion counts!
Repair Service
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
