Telescopes
Problem for Telescopes
Generic problem for all Telescopes
Bushnell 565
By tictack on Jan 02, 2008
i just dug up my parents 18-20 year old Bushnell 565 telescope. i have no cule how to use it or what was included with it .. please help
Comments:
Jan 02, 2008
- thank you so much for your comment it really helped.
Same Problem
Apr 06, 2009
-   I am in the same boat. My wife bought me the Bushnel 565 at a garage sale. I have cleaned it up a bit and I have the Bushnell 565 pointed at the moon at the moment and through the mirror I can see the light from the moon. When I put on the lenses it is all light and no focus. Is there anything I can do? I have tried moving the the mirror in and out witht the spin knob......not sure what else to do...... -   davewichers
Jan 10, 2009
-   I bought the Bushnell 565 from a pawn shop. I took it apart to clean the lhe lenses. Icouldn't get it to focus, before I took it apart. I just wanted to make sure that I put it back together right. What else should I know about it to get it to focus properly?-   Guest
Oct 30, 2008
-   hi i just too Astro-nova100telescope 350power x and i assambled it but i could not see any thing,-   imran_asma
Jan 04, 2008
-   I purchased a Bushnell 565 off craigslist. It has an erecting lens, a Barlow lens, and 2 eyepieces. We can see through the little scope on the top, and we can see an image in the little mirror when we look into the refractor thingy when it is in the telescope. But when we put the lenses in and try to look at objects through the actual lenses in the daytime it is just black (no lens cap on). I've tried several of the suggestions here, but to no avail. Could something be broken inside the telescope? Needless to say at this point, we have no idea if this thing works or if it is just user-error.
Thanks!-   misstessie
Best Solution
posted on Jan 02, 2008
Very Helpful)
swilleyman
Rank: Apprentice
Rating: 91%, 15 votes
There are a few basic things to be aware of.
  1. This is an astronomical telescope so there is no erecting lens combination. So, everything you look at will be upside down.
  2. As a refracting telescope you have virtually no maintenance. A good thing.
  3. This telescope has an equatorial mount. Basically the mount corrects for the off-axis spin of the earth. The quick and dirty way to align the scope is to set position on the mount to 0hrs and 90 degrees. Make sure you are setup on a level surface and then rotate the entire telescope and tripod so that it faces north. Depending on your Latitude and longitude Polaris or the north start will appear higher or lower in the sky. Polaris is called the north star because it is within 1degree of the true north and it is always in the same spot throughout the night and year. The mount will have a third adjustment point near the base to adjust for the apparent change in position caused by the curvature of the earth. Once it is lined up try pointing the telescope at a bright star. The smaller the mm number on the eyepiece the higher the magnification. The beauty of an equatorial mount is that once you have it properly aligned on an object you only have to adjust on axis to keep the object in view.
I could write pages on this please re-post with some more specific questions and I will try my best to answer them for you. Good luck and happy star hopping.
Was this helpful?
Yes
No
2 people thought this was helpful
Popular Solutions for Telescopes
Questions and Unsolved Problems for Telescopes
Answer
Hello, im up in the air with a choice of three telescopes in my price point around $500. Maybe you... (More)
Answer
what is best choice for simple telescope
Answer
connect pc to tv using vga. What button do I push to activate connection
Answer
i have a micronta electric powered zoom telescope 12x-40x-40mm cat. no. 66-203 ----- electric does... (More)
Answer
What is the voltage and battery number for a Tasco red dot Propoint PDP2
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Telescopes:
Top Telescope Experts
Rank: Guru Guru
Solutions: 898
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Telescope Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
