Question about Epson Stylus Photo R300M InkJet Printer
Printing on to CD
How do I set up printer to print on to CD
  • Epson Master
  • 1,879 Answers
The installation cd have the driver and the printcd application:
alternative way to get it is : purchase cd from the vendor
or :
>go to http://support.epson.com, download the printer driver for your operating system and the EasyPrint Utility
>install the printer
>then get the PrintCD application from this link :
http://support.epson.ru/upload/drivertypes/000781/PrintCD_15aE.zip
hope this helps
Posted on Jan 03, 2008
I keep getting the message"the
# Select Print from the File menu.
If you see the message The Epson Printer Driver dealing with CD printing is not installed, click OK.
# Click Tray, select Tray 2, then click OK.
Note: If Tray 2 is not selected, the CD design will print in the wrong position.
# Click Manual Print.
# Make sure Epson Stylus Photo R(your model) is selected.
# Under Paper, select the following settings:
* Source: Manual
* Size: A4
# Click Properties.
# Select CD/DVD or CD/DVD Premium Surface for the Media Type setting.
# Click OK, then click OK again to print.
Mar 11, 2011 | Epson RX595 Photo All-In-One Printer
I keep getting the message "the epson printer driver dealing with cd printing is not installed" when trying to print onto a CD. I have an Epson Stylus Photo R200 using Windows 7. I am working with Print CD...
Try to troubleshoot compatibilty. Right click the program icon of print cd then click troubleshoot compatibility, click try recommended settings, click start the program, click yes to run the program, if it works save the setting. If it doesn't work try to download print cd version compatible with windows 7.
Goodluck.
Jul 14, 2010 | Epson Stylus Photo R200 InkJet Printer
Linked r300 to pc running windows7.can print photos but not cd's.
Download and install the latest print cd software from here.
http://www.epson.co.uk/Printers-and-All-In-Ones/Inkjet/Epson-Stylus-Photo-R300/Drivers-Support?target=driver&languageId=1&driverId=324514&defaultOSId=3&DRV_CATEGORY_CODE=CREATIVITYSOFT
Dec 21, 2009 | Epson Stylus Photo R300 InkJet Printer
The epson printer driver dealing with cd printing is not installed
is there an ok button on that error message? if so just click on OK button and click on a button says manual.
It will let you check on the settings on the printer. paper size should be A4.
on print settings it should let you select on cd/dvd
Note: this only works if you have installed the epson easy print from the epson.com website of your printer model
Feb 07, 2009 | Epson Stylus Photo R200 InkJet Printer
Cover open !
Yepp!
Well, you need to tell your printer that you'r gona print the cd in the cd-sledge, otherwise the printer will try to print on an ordinary paper and since the cd-hedge is open your getting that error message. You the settings when you hit the "print" button and the printer settings appears. Select that you want to print a cd in the cd-hedge.
Good luck to you
Jan 27, 2009 | Canon PIXMA MP600 all-In-One InkJet...
I have a HP Printer C5500 When I try printing something on the CD/DVD Directly I get a Error saying that the printer doesn't support printing directly on the CD while the Printer is meant to print on...
I'm confused.. Are you trying to print to a CD/DVD Drive? Try the print job again, and choose the C5500 as the print device.. Seems that there may be a problem with the print device set-up , and you may have to delete the printer, and reinstall it.
If the printer is designed to print a label on a CD / DVD. then you will have to use the programs provided to accomplish this, as it requires formatting parameters be sent along with the print request. I.E. You can not cut and paste directly to a CD / DVD printer..
Nov 19, 2008 | HP Office Equipment & Supplies
* Source: Manual
* Size: A4
# Click Properties.
Oct 18, 2008 | Epson RX595 Photo All-In-One Printer
Mac OS 10.5 Leopard
As per someone elses post here:
* Source: Manual
* Size: A4
# Click Properties.
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Mac OS 10.5 Leopard
First, install "epson easyprint" from the epson website. Its found under drivers and support for your unit.
Then click ok on that error message about "driver dealing with..."
After you click ok on the message, you will get another window where you will find a "manual print" button. Click on this manual print button and this will take you to the next window where you have to select "A4 as the paper size" and "CD/DVD as the paper type and paper path" . After this, click print... it should start to print! This is just a workaround until epson gets a patch for leopard for print cd........hopefully
Nov 09, 2007 | Epson Stylus Photo R1800 InkJet Printer
Epson Stylus Photo R300M InkJet Printer Logo
177 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
