Audio Shelf Systems
Problem for Audio Shelf Systems
Generic problem for all Audio Shelf Systems
Malfunctioning Pioneer XC-IS21t
By cre-8-er on Jan 02, 2008
I have a Pioneer XC-IS21T and haven't used it for a few years. I went to use it yesterday and in does not work. Everything seems to be working properly, but there is no power to the speakers. This unit has a separate amp with a gauge that monitors the power. All the lights turn on, the cd spins, the tape deck operates, the speakers just don't speak. They don't even make a hiss. I know the speakers are ok because I hooked a battery to them and they made noise. The problem seems to be in the amp. When I turn the volume dial, the needle on the gauge doesn't move. The amp makes a clicking sound every time I hit a button on the main unit. It might be a problem with the power switching(?). I took it all apart and could find nothing. There was a small circuit board laying loose that may be the culprit. It only has 2 small contact points on it but doesn't seem to attach to anything. It is labeled "AWU7349" and "NE M PF2" and "BIND ASS'Y".
Sorry for the long description. Can anyone help?
Same Problem
Sep 30, 2008
-   Exact same issue with mine as well.-   Guest
Aug 21, 2008
-   almost identical problem to that described, except mine stopped working over a move.-   Guest
Aug 02, 2008
-   everything seems to work, the head unit dosent seem to have a problem, but the amp is not working. the blue lights dont light up and the power meter is not working. -   chuby2024
Solution #1
posted on Nov 16, 2008
Not Rated)
masterguy77
Rank: Apprentice
Rating: 0%, 0 votes
I'm not sure what that could be but probably the amp. section. I have a xc-is21t, that came out in year 2000, I use it almost everyday, and it works excellent. Unfortunately a friend of mine has dropped the whole unit on the floor, and guess what it's still works perfectly, only problem the sliding door for the cd(but only the see thru plastic part) is broken and I'm not sure where can I find this part. I wrote a letter to Pioneer.com, so hopefully they can locate the part for me. The only problem with this model that it doesn't play mp3 but again this was only made in year 2000.
Was this helpful?
Yes
No
Solution #2
posted on Jul 02, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Haha! Your amp is french fried. Garbage.
Solution #3
posted on Mar 23, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
BUY A NEW ONE
Popular Solutions for Audio Shelf Systems
Questions and Unsolved Problems for Audio Shelf Systems
Answer
Does the Sharp CD C602 have a light in the main window?
Answer
I have a Boston Acoustics Microsystem, and the CD player just stopped working. When you insert a CD,... (More)
Answer
At low volume the Right Channel Speaker cuts in and out. When i turn the volume up it stops. Ive... (More)
Answer
My CD player is stuck on disc 1. The thing that makes the cd spin will not go down or spin the cd.... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Audio Shelf Systems:
Top Audio Shelf System Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Audio Shelf System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
