Sears LXI Slimview 50" projection TV has horizontal distortion
My 10 year old Sears LXI Slimview has recently started displaying horizontal distortion in the image on both the cable coax input channels and the VCR/DVD input (Yellow/Red/Whiite cables). When accessing the menus, the distortion is not there. There is a slight "jump" up & down on the image (approx 2") every few seconds that you can see in the menus, but no side to side distortion like in the channels. On the cable channels and the VCR/DVD, the left edge of the picture is ragged (offset 2" in some places) and the crresponding lines are shifted all the way across the screen. I took the back off and tightened up the coax where it goes through the back. I checked the connections and fuses and could not see any visible damage or loose solder joints. I did not examine the lamp connections. I noticed all the little adjustment knobs for the lamps and some more that I don't recognize. (I fix computers for a living, not TVs!!) Any ideas on the trouble and the fix for this problem?
Sears Roebuck model 626.54638 392 Chassis PTV515-AH01. (I think this is a Philips/Magnavox chassis) I do not have a schematic. Thanks for any suggestions!
Angela
  • 5 Answers
SOURCE: convergence picture adjustment?
I had the same problem where all of a sudden it started bowing on top and bottom and the colors were bad. I read on here and other sites about the 2 convergance chips so I figured why not try as the tv was going to get thrown away because I could not find anyone that would touch it. Well I ordered 2 stk392-120's (I know others are saying use the 150's or 180's but I just wanted to put the same ones that were in there) I ordered them from electronix.com for 9.99 each plus 6.60 for shipping they took 3 days to get here and I installed them tonight and it worked great. The whole thing took only about 2 hours from start to finish. Here's a couple of tips....the chips are on the far left when looking at the tv from the back, make sure you mark with a marker where the wires go that you have to unplug as there are about 10 of them, each chip has 19 pins that you will have to soder make sure you have a soder ****** to get all the old soder up as you are heating them up, after you are done puting it back together leave the back cover off and turn it on, then go into your menu and go to pictureand go to manual converge and go to undo multpoint and restore factory as this will reset it all. Then if your color is still a little off as mine was there are 6 knobs in the back of the tv by the chips you were working on, find a channel with a lot of colors and try adjusting the top 3 a little at a time till you get the right color that you like. This should do it. It took 26 bucks and 2 hours for me to fix a tv I was ready to replace, thank god for the internet to be able to look stuff like this up. Good luck!
Posted on May 09, 2008
hakimmadina_
  • 155 Answers
SOURCE: My 60'' LXI slimview television will only save one chanel.
If you have remote control for the channels on your set, try to push menu then choose "memorize channel" or choose "cable" then do the channel memory.
Thanks.
Posted on Aug 16, 2009
techman007
  • 1112 Answers
SOURCE: 55 inch mitsubishi rear projection tv red lamp out of adjustment
Have convergence IC's replaced. I believe this unit uses STK-392-570 convergence IC's Only one has gone bad but replace them both, because if one has failed then the other is not far behind, for Blue and Green. One handles Red, One handles BLUE and Grn. There are only two of them in the set, They are the two largest IC's in the entire set.
Posted on Oct 01, 2009
johnnydiode
  • 647 Answers
SOURCE: Replacement Lamps/Bulbs for Philips 50P8341 Rear Projection TV
These are both CRT type TV's(3 picture tubes drive the image) with different screen sizes and the CRT's are not interchangeable
Posted on Oct 24, 2009
Testimonial: "Many thanks to johnnydiode and all the others on this site sharing their knowledge and providing a valuable service."
texasdan
  • 60 Answers
SOURCE: Mitsubishi WD-52525 DLP HDTV screen went bad
I repaired 3 sets and found many surface-mount caps were bad on four boards. After using an ESR meter and finding so many bad caps, I ended up replacing most of them (about 100). The parts were cheap, but it took me about 10-12 hours to repair. I've seen so-called capacitor repair kits on the web that only address the large caps on the power board. You can buy these individual caps at Mouser.com for under $10.00. Luckily people toss these sets so I have 3 awesome sets that only cost me labor and about $30.00. Sorry for the bad news about the caps.
Posted on Apr 21, 2010
Thanks.
Aug 16, 2009 | Televison & Video
I have a Slim-View LXI TV Model # PTV 515 AHO1 Has no Picture
while i dont have a true answer, I can tell you its a magnavox tv sold by sears produced back in 93. Ours just started doing this last week. I couldnt find any help online so we replaced it with a new led flat panel. WOW what a difference, the LXI was great for the past 17 years but the new tvs are better. We put the LXI in the garage because we couldnt throw it away. That tv was like a family member, if i figure out how to fix it i will post the how to.
Feb 24, 2009 | JVC Televison & Video
Help on set up instruction and codes
I have an older model slimview lxi projection screen TV, Model number 62654628391, Serial Number 31056978. This projection was manufactured November 1993. This projection was given to me because they wanted. the Problem that I'm having with this projection is that the colors needs to be adjusted and the PIP needs to set . I lost the owner manuel to the slimview lxi. Please help me as soon as you can. can I get a tip on what to do. Tammy
Sep 12, 2008 | Televison & Video
Mitsubishi VS-50707
Click here to get more info on the subject and also check the other links in that post.
Good Luck.
Apr 29, 2008 | Mitsubishi VS-50707 50" Rear Projection...
Mitsubishi VS-60705 Horizontal Hold issue. Hi, I have a projection TV thatis about 7 years old. I moved and recently hooked it up after sitting for 1 year. It worked great. 2 weeks later I turn it on and...
CHECK C2C52 10 UFD @ 50 V OFF THE BASE OF Q2C51 ON THE SIGNAL PCB. 2. CHECK C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 (9-VOLT REGULATOR) ON THE SIGNAL PCB.
Dec 17, 2007 | Mitsubishi CS-35707 35" TV
Diagonal distorted picture
convergance amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Dec 14, 2007 | Toshiba 50H72 50" Rear Projection...
Rca jack input very distorted
This is probably a short in the TV, most likely a ground problem.
Oct 19, 2007 | Hitachi 50UX57B 50" Rear Projection...
Lines in picture
I had this problem around the time my TV was 3 years old. I ended up having to get it repaired at a TV repair place, it cost me $375.
Sep 24, 2007 | Toshiba 57H83 57" Rear Projection HDTV
Projection TV with Distorted picture
You have one of two different problem. You have bad solder connections on the convergence amp IC's, or you have bad convergence amp IC's. By the way it is acting, I bet if you or someone else resolders all of the pins on both IC,s your problem will go away. But if you keep letting it do this, it will most likely cost you double to repair in the future. Good Luck
Aug 11, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Televison & Video Logo
819 people viewed this question
Top Televison & Video Experts
